Results 1 to 10 of 13
Thread: Waistcoat style
    15th April 08
    WV
    Waistcoat style
    I noticed in a photo in the kilts in media thread that Prince Charles is wearing a waistcoat that has a 'horizontal' bottom to it; the bottom is cut in a straight line. Unlike most that I've seen which are 'angled' or rounded from the bottom button down to the bottom. Is there a reason, other than taste, that his waistcoat is like that?
    25th March 08
    Louisville, Kentucky
    Waistcoats worn with the kilt are often made with a straight bottom edge, like the Duke is wearing. This form of waistcoat doesn't get in the way of the sporran. His tailoring is much better than that illustrated in the photo you included of the Argyll jacket! In that picture, the waistcoat just doesn't seem to "fit" properly...which is what one would expect in the difference between mass-produced and bespoke clothing.
    15th April 08
    WV
    Other than the Prince, I've not seen a vest like that. Even the illustrations at Scotweb for their made to measure waistcoats are not straight along the bottom. The image I posted was from the Tartan Museum, fwiw.
    Could you wear a waistcoat like that without a jacket?
    16th May 08
    forgotten
    21st Century Kilts has waistcoats cut straight across the bottom.
    If you see abbreviations, initials or acronyms you do not know the Xmarks FAQ section on abbreviations may help.
    www.xmarksthescot.com/forum/faq.php?faq=xmarks_faq#faq_faq_abbr
    15th April 08
    WV
    Quote Originally Posted by Friday View Post
    ahh, so they do, but they're not exactly selling stereotypical kilts.
    Is the straight cut a new trend ?Is the straight cut of the princes' an homage to a new trend?
    The higher and straight across the bottom style of waistcoat is actually a bit older than the ones that are longer and have the "notches" at the bottom front.
    When men wore their trousers at the natural waist the waistcoat was cut to just cover the waistband of the trousers.
    On these waistcoats the bottom was usually cut almost straight across and you always left the bottom button undone.
    As mens trousers began to be worn lower (beginning around the period between the wars) the waistcoat was lengthened in the front and the two "notches" were added to simulate the unbuttoned bottom button.
    When I was growing up the rule was that if the waistcoat had a straight bottom you left the bottom button undone. If the waistcoat had notches than you buttoned all the buttons because it was already open at the bottom.
    Today's jacket and waistcoat styles are fairly modern. And almost all the jackets are made by a very small group of companies centered around York, England. most Kilt companies that buy their jackets today probably have them done by one of these companies. So they all look exactly the same.
    To get a Jacket and Waistcoat not from this "cookie cutter" style you are talking custom or bespoke. Think expensive.
    The high end companies like 21st Century Kilts can afford these custom Jackets. While the rest of us are stuck with "normal".
    I wear the kilt because:
    Swish + Swagger = Swoon.
    10th March 07
    I actually altered a regular waistcoat to have the straight bottom and I absolutely agree that it fits far more comfortably and looks a lot sharper.
    The reason they are seen so rarely is that so few people can afford anything but the mas produced highland attire most of the shops sell. (Which is usually great quality and looks great, too.)
    15th April 08
    WV
    The higher and straight across the bottom style of waistcoat is actually a bit older than the ones that are longer and have the "notches" at the bottom front....................
    Thanks very much for that explanation.
    If I were to modify a waistcoat for a straight bottom, where should the bottom of the waistcoat be? At the navel so that it covers the rise of the kilt?
    Also, would it be OK to wear it without a jacket? I like the look also and agree it does look 'sharper'
    thanks again!
    18th September 08
    Northern Virginia
    You might also look at some of the waistcoats offered by vendors who cater to the Cowboy Action Shooting crowd. Most have the points, but there are some that are straight across, and a few outfits will make you a waistcoat for a fairly reasonable price.
    Or you can do what I've done, and modified an existed pointed waistcoat so that it is straight across. It's not particularly hard.
    US Marine (1970-1999)
    24th March 08
    the Highlands of Central Oregon
    That's a shawl lapel waistcoat. That style, as well as notch lapel and several others were very popular from about the mid 19th century to the early 20th century. Almost all were cut with a straight bottom and most were worn with the bottom button unfastened.
    A straight bottom, high gorge, notch lapel waistcoat is what I usually wear...with and without a kilt.
  1. Waistcoat On It's Own Hanger?
    By Bugbear in forum How to Accessorize your Kilt
    Last Post: 6th May 09, 11:20 AM
  2. PC waistcoat help
    By berserkbishop in forum How to Accessorize your Kilt
    Last Post: 30th April 08, 09:57 PM
  3. Help on waistcoat
    Last Post: 16th March 07, 02:51 PM
  4. Kilt with a waistcoat and tie?????
    By moovet in forum General Kilt Talk
    Last Post: 30th January 07, 01:58 PM
