Results 1 to 10 of 16
Thread: Waistcoats
    22nd February 09
    Denton, TX, USA
    Waistcoats
    Hey everyone,
    Are there any differences between waistcoats built for a kilt and those used with modern suits, especially in their length? I am really not very knowledgeable about such things and am considering getting some of my extra tartan made into a waistcoat. I am unfamiliar with possible differences in styles of waistcoats, so any information any of you may have would be greatly appreciated.
    May the grace of the Lord Jesus Christ, and the love of God, and the fellowship of the Holy Spirit be with you all.
    2 Corinthians 13:14
    David E. Gregory
    25th March 08
    Louisville, Kentucky
    Quote Originally Posted by ixoyedeg View Post
    Hey everyone,
    Hello David,
    Yes, there are some differences. A waistcoat to be worn with the kilt is usually shorter than one worn with a suit, due to the higher rise of the kilt. Often-times the kilt waistcoat is cut wider at the bottom to better accomodate a sporran (many gentlemen prefer a flat bottomed waistcoat for that very reason).
    As you are interested in a tartan waistcoat, might I recommend that it be made up on the bias (diagonal, as it were)? This makes for a very beautiful--and traditional--vestment! Is this an evening waistcoat? If it is, you most likely will want one with three or four buttons; daywear waistcoats five or six.
    Sandford MacLean
    22nd November 07
    US
    JSFMACLJR brings up three button and four button evening waistcoats. The difference was pointed out to me not too long ago. The four button, evening waistcoats tend to have a "U" shaped neck line that is slightly higher than the "V" shaped neck line that is often on the three button waistcoats.
    If you are thinking of a daywear waistcoat to go with an Argyle type jacket, then a regular, five button waistcoat pattern could be modified to work with a kilt. Basically, the hem is raised about an inch and a half, and the angled cutaway edges are raised a bit which makes the cutaway a little wider. I've taken a couple of regular waistcoats and modified them this way.
    I think there is a daywear waistcoat style that has a higher neckline than the typical five button waistcoat, but I don't know a lot about that.
    21st February 04
    Michigan
    Waistcoats meant to wear with a suit will generally not work well with a kilt, I've found. Modern waistcoats are too long all the way around. Those made to go with suits from the early 20th century (say, 1920s-1940s) are the correct length in the back because of the high trousers worn then, but they usually (not always) have a long, curved 'swallowtail' in the front, which gets in the way of the sporran. Kilt waistcoats for daywear usually combine these two, vintage length and a modern, cropped front.
    Kiltio Ergo Sum.
    22nd February 09
    Denton, TX, USA
    Thanks everyone for the replies. I was hoping it might be a more versatile accoutrement which could be used both ways, but alas...
    Thank you all for the information it is helpful to figuring out what I need.
    2 Corinthians 13:14
    David E. Gregory
    17th December 07
    Staunton, Va
    There is a trick to this...
    Actually, for most men, an ordinary suit waistcoat works fine-- here's the trick: If you are (say) a 44 Regular, get a 44 Short waistcoat. Likewise, if you are a 44 Long, look for a 44 Regular. If you are a 44 Short, then you need a 44 Cadet. Admittedly the short guys have a rougher time of it but, if you are "Mr. Average", it's not impossible to get a suit waistcoat that works with a kilt.
    22nd November 07
    US
    I see where you're going with that. I have a gray waistcoat that I can turn up the bottum an inch and a half or so all the way around, and it would work fine with a kilt. Put a safetypin on either side and it's good to go. It just happens to be the right shape and length to do that. I need the waistcoat more for my suits, so I can't hem it.
    That is a five button waistcoat; I don't know about the evening waistcoats.
    14th March 06
    Thanks for the very sensible tip.
    24th March 08
    the Highlands of Central Oregon
    Quote Originally Posted by Ted Crocker View Post
    Back in the day...Victorian or Edwardian days...men wore their trousers much higher on the torso, very much at roughly the same level as a kilt is supposed to be worn (think military trews, if nothing else). Waistcoats were shorter by comparison to what is worn today and were often cut straight across--no points on the bottom.
    For me that provides a rough guide for waistcoats with kilts. Not the only guide or the only look but one that is perfectly in sync with wearing a kilt and a sporran.
    My suggestion would be to try turning up the points of your contemporary vest to create a straight bottom and see how that looks rather than trying to turn it up all the way around.
    BTW, five button waistcoats with straight bottoms (and high gorge notched-lapels are readily available, in many different fabrics and colours. And almost always of higher quality construction than the one that came with your suit--which is always sort of an afterthought.
    22nd November 07
    US
    Quote Originally Posted by DWFII View Post
    Yes, that works well to turn the points up on some waistcoats.
    I was trying to ask about some of the other neck line styles of waistcoats in a thread, but there's not much excitement over there.
    I've also seen waistcoats, in old pictures, that have high neck lines, but do not have the notched-lapels. I don't recall that they were being worn with kilts, though.
    From where are the waistcoats readily available, DWFII?
  1. Patchwork Waistcoats?
    By Bugbear in forum How to Accessorize your Kilt
    Last Post: 8th April 09, 12:11 AM
  2. Waistcoats and Vests
    By Aracos mac Domhnaill in forum How to Accessorize your Kilt
    Last Post: 23rd June 08, 11:02 AM
  3. Waistcoats
    By orangehaggis in forum How to Accessorize your Kilt
    Last Post: 7th May 07, 04:09 PM
  4. Jackets and waistcoats
    By Mike n NC in forum How to Accessorize your Kilt
    Last Post: 4th November 04, 09:15 PM
