Results 1 to 10 of 20
    22nd January 06
    Maple Ridge, BC, Canada
    X Marks kilt pin repair question
    When I strapped on my BC tartan kilt to have photos taken last week, I found my X Marks kilt pin dangling. Because of the hem on the edge, the pin and clasp were easily found. My question is how I might go about repairing this.
    I did take it into our shop at work and asked about either welding or soldering. Apparently neither were terribly successful. Krazy Glue was for about five minutes. Any suggestions, Gents? I'd really like to be able to continue to use it.
    Thanks in advance.
    29th January 06
    Asheville, NC
    Hit both surfaces with a spot of sandpaper and attach with epoxy glue.
    I have had to repair all 7 of the pins I got. Each one had the studs soldered in a very poor way. Lots of cold solder and lots of soot.
    I use soft No.2 Solder from a jewlery and Lapadary shop. It melts as a temp. far lower than the rest of the pin. It is used by silversmiths when they want to attach fastenings and don't want to re-polish the front surface.
    Use lots of flux. Use a needle flame butane torch. Place the pin on a heat sink to prevent blistering the varnish on the good side.
    I did all seven kilt pins in about an hour and that includes first removing the original solder joint, prepping the surface with sandpaper, and cleaning afterwards.
    I wear the kilt because:
    Swish + Swagger = Swoon.
    Get the best, strongest two part epoxy you can get. Use that to re-attach the broken (pin) and a small blob to strengthen the othe. Less than $5 and 5 minutes time to fix.
    16th July 06
    Sierra Vista, Arizona, USA
    I use a low melting pt. solder and flux that is designed to fuse dissimilar metals. It works great. I also use a small butane torch for the heat source. It is a little expensive >$20 at a welding supply store. O'Neille
    Umm,
    Should those of us who have good pins still, be strengthening them somehow to avoid this?
    Thanks,
    Ron
    31st May 06
    Relevant question:
    Are the breaking pins from tyhe first batch, the second or both?
    The second batch is the one shipped this summer (2006).
    6th November 05
    The Hague, The Netherlands
    I removed both pins, filed and sanded the back of the pin and replaced them with a safety lock pin...2 part metal-epoxy.
    23rd November 05
    Easton , PA
    I also had 1 loose upon receiving my pin. KCW had stated that there was some problem with them, and would swap, but I used a 2 part Epoxy, and reinforced the other with it as well and I've had no problem so far.
    Mark Dockendorf
    Left on the Right Coast
    22nd January 06
    Quote Originally Posted by MacWage
    Relevant question:
    Mine was from the second batch.
