Results 1 to 10 of 23
    22nd November 07
    US
    Cutting Walking Sticks, Questions
    I started cutting assorted branches from various kinds of trees for walking sticks today.
    As I brought up in another thread, I have been sealing the ends and cuts with wood glue, and usually let them dry down for a couple of years.
    Any advice on preparing the sticks?
    Anyone peal the bark while the sticks are still green?
    Finally, since I grow trees... has anyone ever tried shaping a branch into a crook as the branch grows?
    Thank you.
    26th November 10
    Weatherford, Texas
    I normally peel the bark within a day or two of cutting. I also have never
    sealed the ends. The only ones I've had warp or split are willow.
    I have never tried to shape a living branch. I don't have that much patience.
    22nd December 10
    smithfield va
    Speaking as a guy who owns a sawmill, and often cuts stranglewood saplings...leave the bark on, dip the cut ends in wax, put your branches up in top of the shed or something to dry for a few months...the bark wil transpire the moisture slowly from the wood, without checking in the grain,,the wax keeps the moisture from coming out of the cut ends, also causing checking..
    29th January 06
    Asheville, NC
    Quote Originally Posted by Llwyd View Post
    22nd November 07
    US
    All right, thanks. what about the smaller branches that are removed, should I seal those cuts, too?
    24th February 09
    Georgia
    I have, in order to keep the sticks straight, lashed green wood to something that cannot bend until the wood has dried. A 6 foot long section of pipe from a chain link fence, or galvanized water pipe, and some 3/4 inch wide strips of inner tube work for me.
    MacBean is offline Oops, it seems this member needs to update their email address
    21st October 09
    Valley Forge, PA (USA)
    Those who built some of the Zen temples in Japan curved their wood on the tree, and sometimes over several generations to obtain exactly the 'natural' curves they wanted for porch pillars. I love the idea.
    Timber for ships and roofs used to be grown to the right shape and size in English woodland - it was very valuable.
    My father's father was a barber, and one of the sidelines for most barbers was making walking sticks. They had a steamer out the back of the shop and would soften the materials so as to be able to shape the tops and straighten out unwanted bends.
    One rather strange material used was cabbage stalks - presumably from plants used for seed, or which had 'bolted'. I have a vague recollection that they were imported from the Channel Islands.
    Anne the Pleater :ootd:
    3rd July 09
    Canada
    Shaping a living branch could work, but you would have to allow for the natural tendency of a tree to spring away from what it perceives as a heavy weight- I refer to the reason why it's necessary to brace a transplanted tree from more than one side. Take away the single support wire and boing! you find the tree leaning away from that point. So, I imagine that working with the tree in the way you propose will require some experimenting.
    5th November 08
    Marion, NC
    I tied some gum saplings into crooks, but then sold the house (and yard where they were growing) so now that's over.
    I've never sealed any walking sticks, since i don;t care wheteher they crack or not. I do like to cut them in the spring or summer when the sap's up, since i think the stick stays springier after it dries. I don't know if that's true; I just think it is.
    --dbh
  1. self made walking sticks
    By Rollo in forum How to Accessorize your Kilt
    Last Post: 21st September 09, 03:32 AM
  2. Walking Sticks
    By McMurdo in forum How to Accessorize your Kilt
    Last Post: 11th August 09, 10:18 AM
  3. officer's walking sticks...
    By macwilkin in forum How to Accessorize your Kilt
    Last Post: 4th February 09, 03:35 PM
  4. Going Stag with Walking Sticks
    By Kilted Carver in forum DIY Showroom
    Last Post: 12th January 09, 04:32 AM
  5. Walking sticks
    By Jerry in forum How to Accessorize your Kilt
    Last Post: 11th July 05, 06:12 AM
