20th January 07, 02:29 PM
Haggis woes.....
A nice low simmer on the presentation haggis for tonight, and suddenly, the entire skin just splits and voila - a big heap of paunchless haggis.....
Any ideas on how to make it pretty to pipe in???
I wasn't expecting this........
20th January 07, 03:11 PM
Oh not good.
This did happen to me once however it was not for anything like a Burns night, I just ate it the way it was, but I really dont know if it can be fixed.
I am not sure how to bandage a haggi, could you get another skin to stuff it into?
21st March 07, 08:02 AM
o'ercooked... tae hot... split the casing...
weel... nay much ya can dae...
if ya have the time...
let it cool enough tae touch...
then sew the casing tegither wi thread.... restuff as much as ya can...
21st March 07, 08:17 AM
I know--I cheat.
Try putting the thing into a baking bag (from the grocery) and boil it a while longer. If the bag is pulled tight and turned upside down, it'll look pretty good.
Jim Killman
21st March 07, 10:15 AM
The reason most Haggis split when reheating is because nothing has been put in the bottom of the pan to prevent the Haggis from touching. Even at a simmer the heat on the bottom of the pan is too intense and that will split the casing. A rack of some kind on the bottom of the pan will prevent this. You can also leave the Haggis in the shrink wrap it came in (or wrap it tightly in plastic if it didn't) to help. Also remember 30 to 60 minutes is all that is required to heat all but the biggest Haggis. It will already be fully cooked so you just need to heat it through.
That said, the above method is not what I use. I don't simmer the Haggis I steam them. I remove the shrink wrap and then tightly wrap the Haggis in plastic wrap*. In the bottom of a large pan with a lid I put 1 inch of water. I then place a rack in the bottom of the pan. Bring the water to a boil, turn the water down to a simmer, place your haggis on the rack, put the lid on and then remove the haggis when it is hot, 30 - 60 minutes depending on size.
The best part of this method is if you need to heat up a number of Haggis at the same time the method can be done in the oven. Place a rack in a roasting pan, fill with an inch of boiling water, put your haggis in, cover tightly, place in a preheated 350 F oven and wait. Similar timing is used.
As a caterer I have reheated well over a thousand Haggis using this method and never had a problem with even one.
* I re-wrap in plastic wrap, rather than use the shrink wrap because I find you are more likely to get burned getting the shrink wrap off and so the process is slower. I fact that matters to a caterer.
By BLAZN in forum DIY Showroom
Last Post: 22nd November 06, 05:27 PM
Last Post: 6th September 06, 10:23 AM
By Tattoo Bradley in forum Miscellaneous Forum
Last Post: 2nd July 06, 10:04 AM
By Big Paul in forum General Celtic Music Talk
Last Post: 17th February 06, 06:52 PM
