Results 1 to 6 of 6
Thread: Kilt Pin
    27th September 04
    Amelia County, Virginia, USA
    Kilt Pin
    I found this at the kiltstore. While it's not the Xmarks pin, it could serve as one.
    Jerry, Kilted Old Fart.
    8th November 05
    Northglenn, Colorado, USA
    Very nice...I need a second one now to go on the Black Watch Stillwater heavyweight. Have to go over and check it out.
    15th March 06
    South Carolina
    That's a sweet kiltpin!
    20th February 06
    Falmouth, Maine, USA
    How does one properly use a kilt pin?
    Quote Originally Posted by JerMc
    Nice looking pin, but frankly I must confess I don't know how to use one. Does it hold the front and under aprons together or just acts as a weight on the lower part of the front apron? Doesn't all that pinning and unpinning eventually wear on the fabric of the kilt?
    Thanks,
    Last edited by longshadows; 30th March 06 at 07:20 AM. Reason: removed the graphic from the quote.
    7th April 05
    Frederick, Maryland, USA
    Quote Originally Posted by longshadows
    Thanks,
    The advice here is to NEVER pin the aprons together as this could cause tearing if it caught on something. The pin is primarily decoration and maybe a little weight. The best advice on unpinning is to have a different pin for each kilt and to only remove it when you need to clean the kilt.
    30th September 05
    Central Highlands, PA
    I only attach it to the front apron and then I don't remove it unless I am having the kilt cleaned. I have a kilt pin for each kilt. It does add a little weight to hold the front apron in place.
