12th January 07, 10:54 PM
Tire chains recommendations?
So this whole winter driving thing is new to me, just moved to eastern WA from SoCal this summer. The weather really isn't too bad here, not much snow or ice, just damn cold. However, I'm looking to head over the hills to Seattle for a weekend or two before winter is over, and would like to be somewhat prepared if need be.
I've thought about getting some of the diagonal zig-zag Z-cable type. I've had a couple folks say they work great, and a couple others say they're crap. I guess basically I'm wondering if I should go with the Z-cable setup or a more traditional diamond pattern chain setup.
Now, if it makes a difference, this is for my Mitsubishi Mirage, a small FWD hatchback.
13th January 07, 12:40 AM
I used both on a Suzuki Samurai when I lived in Utah. I think you would get great results from the zlink style considering your vehicle.
13th January 07, 09:47 AM
On a front wheel drive, try to avoid traditional chains. Stay with a cable type otherwise your suspension will take a beating.
Gentleman of Substance
13th January 07, 11:06 AM
For a vehicle that small, I like a parallel cable type. You know, the kind that look like this: IIIIIIII Made out of cables with little metal rings on the cross pieces to bite the ice.
13th January 07, 04:33 PM
The regular cable chains will be good enough. That said, it might be worthwhile checking some of the used tire shops in the tri-cities area for some decent snow tires. I have a set of four Gislaved NordFrost Q snow tires on my '83 Volvo wagon. Haven't had any trouble in the latest snowstorm getting around. The previous one, I did have a couple issues, but that was because I was trying to go up a hill at 10 mph and had the person in front of me almost stop.
A suggestion I do have, whichever route (chains or studs) you go, tend to use the higher gears, but let the car run at a lower rpm than normal. Yes, you may be lugging it a bit, but you'll keep your traction. By the time I'm travelling 25-30 mph, I'm already in 4th gear when I'm in snowy conditions. Also, be light on the throttle. Another thing I learned pretty quickly in the second snowstorm I ever drove in, when you need to make a turn while going downhill, don't hit the brakes. If it's icy, the car goes straight even if your steering wheel is turned. Once I released the brake pedal, I made the turn, no problem.
-J
13th January 07, 05:04 PM
one thing I miss about my standard trans. vehicle .....snow driving was SO much easier in that you could regulate speed better and down shift for those turns!
my automatic 4X4 ....not so much!!
Irish diplomacy: is telling a man to go to he)) in such a way that he looks forward to the trip!
13th January 07, 10:19 PM
I'm not too worried about snow driving technique, I'm familiar enough with that. Spent a few years back in central Missouri, had some good icy days (weeks!) there. I don't particularly want to deal with snow tires, just bought new tires for the car a couple months ago, and for 95% of the winter here the roads are clean and dry. I'm looking at chains to have should I get stuck with bad weather on the pass.
Oh, and I do have a manual transmission, and am used to short-shifting when needed, even starting out in second gear sometimes.
Why would it take any more beating than rear wheel drive using traditional chains?
14th January 07, 12:19 AM
The thickness of the links of chain cause a bump-bump-bump effect that is bad for the cv joints of a front wheel drive vehicle. On a rear wheel drive, you have a solid axle with a differential in the center.
14th January 07, 12:47 AM
Ah... I do enough wrenching (including having replaced my front axles myself) that I should've realized that.
14th January 07, 09:19 AM
Check the local regulations. In some places (like where I live, for instance,) they're illegal for road use.
Kiltio Ergo Sum.
By Andrew Green in forum General Celtic Music Talk
Last Post: 16th September 06, 07:11 AM
By arows1faith in forum Kilt Advice
Last Post: 7th September 06, 08:40 AM
Last Post: 7th August 05, 09:40 AM
