Results 1 to 10 of 19
Thread: Bagpipe Lessons
    7th September 05
    Portland, OR - USA
    Bagpipe Lessons
    Not sure if this is the right area to post in, but I'll take my chances. I'm interested in taking bagpipe lessons in Northern VA. Anyone have any suggestions?
    Graham's Avatar
    Graham is offline Oops, it seems this member needs to update their email address
    4th February 04
    Tasmania, Australia
    As a failed piper, all I can say is "best of luck". If you can survive the 'misery stick" and come out a piper, then i raise a glass to you!
    7th September 05
    Portland, OR - USA
    I enjoy a challenge!
    17th June 05
    Jacksonville, FL
    7th September 05
    Portland, OR - USA
    Thanks!
    13th August 05
    NJ, USA
    Piping info
    www.bobdunsire.com/cgi-bin/ubb/ultimatebb.php
    Probably the best source for bagpipe information on the Web. All levels, from beginning to open pipers. You can pick up a link from that site to Dunsire's Bagpipe Web Directory, a compendium of links to all things piping related on the Web.
    All skill and effort is to no avail when an angel pees down your drones.
    30th September 05
    Western Pennsylvania
    How far north are you in Virginia? I may be able to recommend a couple people based on where you are located.
    Drone on!
    WSG
    Quote Originally Posted by Kilted Taper
    The tradition continues!
    The Pipers Gathering at Killington, VT
    27th September 04
    Amelia County, Virginia, USA
    My daughter has expressed interest also, so I talked with the drum major of a local pipe (The Saint Andrews Pipes and Drums of Richmond) band at the Richmond show yesterday and he told me that they give lessons and have classes from raw beginners to advanced. You might try contacting a local pipe and drum group where you live. I suspect a lot of them offer lessons. It would be a good way to keep thier ranks filled.
    Jerry, Kilted Old Fart.
    7th September 05
    Portland, OR - USA
    Quote Originally Posted by JerMc
    Belive it or not, I did contact the Arlington Pipe and Drum, as well as the DC. Neither had anything. I did finally find someone in Alexandria. Sadly, I haven't been able to attend class the last month or so due to work and year end duties.
    6th December 08
    Bagpipe lessons
    HELLO, Where in Alexandria did you find someone to give lessons?
