Results 1 to 10 of 15
    24th April 07
    Duluth, MN
    Pipes for late Xmas gift
    Hello Pipers,
    I've been pondering the purchase of pipes for a late Xmas/40th birthday gift. My father gravitated to the pipes during college, and I've managed to avoid their pull until now.
    This question is for the experienced members out there: Where would you recommend shopping for a beginner set and a chanter?
    Kevin.
    Institutio postulo novus informatio supersto
    Proudly monkeying with tradition since 1967.
    9th June 06
    Midland, TX
    www.toneczar.com
    Dunbar Polys
    30th October 07
    Harrisonburg
    I'm no great piper myself but I dabbled in it 5 years ago. I need to get back into it but I just don't have the time to make the commitment to it.
    Ok, so now that we've established my limited credentials, let me suggest that you start with a chanter alone. Save the money you would have spent on the beginners pipes till later. Or use it to get some lessons if you don't have a pipe band nearby to learn from or you don't wish to play in a pipe band.
    I know several talented pipers and all of them still have their chanters. They're dead useful to practice on, because they're easier to carry around, there's less going on with them and they're quieter (believe me, that's important when you're making your first squeaks). Let other more qualified members weigh in, but I'd say to just start with the chanter.
    2nd July 06
    Madison, Wisconsin
    I think there should be a sticky somewhere about learning pipes, because it's getting tiring to repeat this over and over.
    Buy a chanter.
    Don't even THINK of bagpipes until you've mastered that. Find an instructor, buy a chanter, and practice every day.
    9th June 06
    Midland, TX
    Quote Originally Posted by beloitpiper View Post
    Buy a chanter.
    Hey now. Then just pass the thread by and don't reply if it's that tiresome.
    13th November 07
    Tieton, WA
    Quote Originally Posted by kevinkinney View Post
    Hello Pipers,
    Kevin.
    Ahh, something I know well...
    Many of the top pipemakers would be a great start. Naill, Dunbar, Shepard, Kron to name a very few.
    By chanter, I assume you mean a practice chanter. Don't bother with a blackwood PC. They require more maint. than a poly chanter. It took me splitting two PC tops before I learned my lesson. That being said, there are some blackwood PC's out there that are much older than I am and are in no danger of splitting anytime soon. I've been through 4 PC's, the poly ones are still with me.
    Also, get a PC with counterbored holes. They give a better feel and are a bit less forgiving, making you position your fingers better. Also, they are closer to a pipe chanter therefore making the crossover easier.
    Don't worry about pipes right now. Get a good instructor, a good PC and good book to study, in that order. Most likely your instructor will have a huge influence on your choices.
    I spent better than a year on the PC before making the move to the pipes. You will likely do the same. If your instructor pushes to get you on the pipes faster, question the reason. This is not only tradition, but also the amount of time needed to learn the fingering, learn tunes, learn to listen and strengthen your lip. There'll be plenty of time. Don't rush it.
    Much of this has already been mentioned. I hope it all makes the point.
    Last piece of advise: Make the commitment to practice everyday. A minimum of 15 minutes, with most of my sessions ending around an hour. If I was gearing up for a competition, I'd push it to two hours or more a few weeks before and backing off just before the comp, say, four or five days before only playing 15 to 30 minutes a day.
    Sorry for my ramblings. I just realized that this is more info than you asked for but I hope it helps. Please ignore anything you aren't interested in.....
    And, welcome to the brotherhood.
    T.
    13th May 05
    Native Texan, now located in W. KY/TN
    As my fellow pipers have sagely recommended (this isn't really a suggestion, but de rigeur. Trust us, it is virtually written in stone.) Practice Chanter first, then after a year or so depending on your progress and the INSTRUCTOR (You would be very ill advised to attempt to teach yourself...this "ain't" the tin whistle), you will progress to the pipes.
    Attempting to alter this standard and essential order will result in much frustration, and eventually a very expensive and unused set of pipes shoved into the back of your closet or for sale on Ebay.
    As far as recommendations, I have quite a selection of PC's in my collection, and very much favor the Gibson Long Poly Chanter for feel, tone, and construction.
    Best of luck my friend, and be glad you don't have the bug to maser the Uilleann pipes (those who also play know of what I speak.....whew).
    4th September 05
    Oklahoma
    Seconded. This question comes up all the time, so clearly it would be useful to have a sticky for it.
    As far as the chanter goes, ask your instructor what type he if he's got no preference, then Dunbar, Gibson or Walsh long poly chanters are good; poly because it will survive better, long because it makes it easier to transition tunes to the pipes.
    Quote Originally Posted by TheKiltedWonder View Post
    The chanter isn't like training wheels; that is, it's not something you use for a while and then put away. It IS the first step on learning the pipes, but you'll continue to use it throughout your piping lifetime. In general, when you learn a new tune, you learn it first on the chanter, and then, when it's solid, transition it to the pipes. I would be very suspicious of any piper who claims not to own or use a PC; that's why it's a good idea to spend some money and buy a good one when you start out.
    Good luck!
    --Scott
    "MacDonald the piper stood up in the pulpit,
    He made the pipes skirl out the music divine."
    24th April 07
    Duluth, MN
    Thanks for the quick advice.
    I should have been more specific. I meant *New* Chanter with a set. I've already been playing the chanter on my own for years.
    Kevin.
    6th December 06
    Michigan
    Cheers,Kevin.
    If you are already well versed and proficient on the PC, I'd suggest the Dunbar P1s as a great and relatively inexpensive (as compared to the others out there!) set of nice pipes. I know that the black wood purists would faint over this, but it is true no less!
  1. The late late show
    By Makeitstop in forum Kilts in the Media
    Last Post: 10th September 07, 05:56 PM
  2. Pittsburgh, Pa this Xmas
    By Yaish in forum Kilt Nights
    Last Post: 14th December 06, 04:12 PM
  3. Yet another XMas Party
    By Alan H in forum Show us your pics
    Last Post: 18th December 05, 09:20 AM
  4. The Xmas ensemble...
    Last Post: 15th December 05, 02:55 AM
  5. Xmas stroll
    By philbo in forum General Kilt Talk
    Last Post: 5th December 05, 10:11 PM
