WTB: Argyll/Braemar etc - Not a PC - 42 L to 44
Got It !!!
I am looking for something less formal than a Prince Charlie, preferably in a brown tweed but open to other materials and colours. Generally I wear a 42 L or 42 with let down sleeves. I have tried a 44 Argyll from HoE and was pleased with the fit. My current saxon styled jackets measure about 20 " between armpits and sleeves are from 25 3/4 to 26 1/2" crown to cuff.
Please PM with any offerings you have. I have a US address in Ogdensburg , NY as well as Canadian if that helps.
Cheers !
Found One !!!
The topic of kilt jacket can be confusing at times. Perhaps because of the names that the different makers use.
These names are just what each manufacturer has chosen for their model or style. They may be different for each maker.
But - here are a few hints and tips when looking for a jacket.
There are basically three styles in use today. These are pretty common and what you will find in almost every kilt shop all over the world.
Yes, there are a couple other, more than these three, but we will come to those later.
The most formal style of jacket you will find on the racks of most kilt shops is almost universally called the Prince Charlie. Not Bonny Prince Charlie.
This is a coatee style of jacket that takes its inspiration from the military mess dress coatee.
The Prince Charlie has "tails" in the back.
This is the most formal style of jacket. It has satin lapels. This kicks this jacket up into the range of formality with the tuxedo.
The Prince Charlie coatee is worn with a tuxedo shirt and black bow tie.
The next style of jacket is called by many different names.
The basic design features of this style of jacket is that it is longer than the Prince Charlie. More like a suit coat.
(However, the bottom of a suit coat will end at about the bottom of the buttocks to hide the pucker from the trouser legs.
A jacket cut for a kilt will end at the crest of the buttocks or just about where the pleats are sewn down and tapered.)
This style will normally have a single button front.
It will also usually have epaulettes.
And the pocket flaps will usually be scalloped and have decorative buttons.
And there will be a cut-away to go around the sporran.
Where some of the confusion comes from is the cuff treatment.
If the cuff has a single button you see above on the left, without the small fold over, (Called a 'Closed cuff') the name of the style is not "Argyle" but now "Crail".
If the cuff is the gauntlet style you see in the middle, it is called "Argyle" as this is the Argyle cuff.
If the cuff has the same placket seen on the Prince Charle it will usually be called a "Braemer".
All of these different cuff treatments can be on jackets which are otherwise identical in everything else.
The Argyle/Braemer/Crail style is much more versatile than the Prince Charlie which is only worn for those events where the others, not in kilts, would be in Tuxedo.
If you have an invitation to a formal or Black Tie event, the Argyle may be worn with a tux shirt and black bow tie.
And it can also be worn like a suit coat for less formal events.
With or without the vest.
And if you are brave enough to pull it off, you can wear it with a vest in a contrasting color.
Both the Prince Charlie and the Argyle, are most commonly found, made from a type of fabric called Barathea. This refers to the weave of the fabric.
If you make the exact same Argyle/Braemer/Crail jacket from a Tweed fabric you have what is most commonly called a "Tweed Argyle"
The jacket above is made exactly the same as the Argyle. The only difference is the fabric it is made from.
But again, the jacket cut and style are less formal than the Prince Charlie.
I personally do not own a Prince Charlie. There are too few "Black Tie" events left in the world today. You will still see the Prince Charlie offered in almost every kilt shop. But if you want versatility I would suggest that you investigate either the Argyle/Braemer/Crail made from Black Barathea or the same jacket made from a Tweed fabric.
For a smart, professional, business look this is how you will see me dressed almost every time.
The Following 5 Users say 'Aye' to The Wizard of BC For This Useful Post:
Thus the wording of my title, there is much confusion about nomenclature and I was seeking to convey that I am looking for something less formal than the Prince Charlie. In fact the styles shown by Steve would all pretty much suit me, though I do tend to like the epaulettes, preferably plaited. I also like alliteration! In a perfect world the jacket I would choose is the House of Edgar peat coloured Crail jacket though any of three cuff styles on the same jacket would be okay.
http://www.houseofedgar.com/acatalog/info_764.html
And as he pointed out in regards to the confusion in the naming of styles, their Crail jacket has Braemar cuffs which they refer to as Prince Charlie cuffs
Thanks to the Wizard for his insightful post.
ETA : Just saw Wizard's second post and am curious as to the reason for starting the sleeve measurement at the 1 " mark. I actually measured the sleeve of a jacket 'crown to cuff' as it lay on the bed for my measurements.
