29th August 09, 11:25 AM
Why I Love Polyviscose Kilts
So yesterday I'm ten hours on the road driving back from Tucson. Took longer because I shopped my way home. Had a lot of in and outs of the car, meaning my kilt pleats got new angles of creasing every time.
It was HOT all the way home, well over 100 degrees F even with the car air on, so between my weight and never quite getting the peats perfect my kilt took a LOT of abuse.
Wore my USA Kilts Casual in Red Gordon.
By the time I finally got home it was a mess. I've NEVER seen a kilt with worse or more pleat creases.
Let it hang out over night and today took the steamer to it and in a few short steamer passes the pleats were back, sharp, no creases at all.
Sure beats ironing!
Polyviscose material is bulletproof.
Ron
29th August 09, 12:27 PM
Yep! I couldn't agree more. I love the stuff, too. I just hang mine in the bathroom when I shower. That takes out all the unwanted creases and wrinkles like a charm.
29th August 09, 01:01 PM
29th August 09, 01:14 PM
Thank you Gentlemen,
You have made my decision easy!
Robert "V"
Reason: spelling
29th August 09, 05:35 PM
I have to agree, bulletproof! My USAKilts semi-trad is my most often worn kilt. Wore it 20 hours straight at the Kazoo games, visiting and then the drive home. Hung it up and by morning half the wrinkles were gone already.
29th August 09, 07:51 PM
Now, now, there's PV and there's PV. I handled some PV at Joann's that, umm, wasn't quite like the "good stuff" produced by Marton Mills. To the best of my information and belief after reasonable inquiry, Rocky and Kelly (USAK) use Marton Mills. Quality makers using quality products---that's the ticket, right there.
29th August 09, 07:57 PM
Get a inexpensive white king size pillow case. Place it over the steering wheel when out of the car to keep the wheel cooler. When you are ready to get in the car, sweep your pleats, take the pillow case and wrap around your pleats and hold in front as you slide into the car seat.
If you see abbreviations, initials or acronyms you do not know the Xmarks FAQ section on abbreviations may help.
www.xmarksthescot.com/forum/faq.php?faq=xmarks_faq#faq_faq_abbr
30th August 09, 06:11 AM
You should do a video of this procedure.
Animo non astutia
30th August 09, 06:42 AM
Sounds great and I agree, a video would be really helpful!!
30th August 09, 07:07 AM
I do something similar using a bath towel which I just sit on while driving. The only drawback with my pv kilt is that I find it hard to sweep and tell if the pleats are straight or not after getting into the truck, that where the towel trick comes in.
By NorCalPiper in forum General Kilt Talk
Last Post: 25th February 09, 05:59 AM
Last Post: 7th February 09, 02:02 PM
By KiltedBrewer in forum General Kilt Talk
Last Post: 20th January 09, 08:43 PM
By Colin in forum General Kilt Talk
Last Post: 19th July 05, 09:19 AM
Last Post: 7th May 05, 06:22 AM
