20th July 17, 02:27 AM
Cutting pleats in a low yardage knife pleat
I have a budget 5 yard kilt from Glenisla. As was noted by Steve a few months ago, it was made to the barest minimum standard for a wool kilt. Yet, it is still made from Lochcarron Strome (as confirmed by Craig at Kilts4Less from whom I bought the kilt when I first started wearing them).
There is no steeking or canvas interfacing. The buckles are attached directly to the wool. My intent it to take the lining and buckles/straps off and finish it properly. I have some of the same fabric on order from Lochcarron, with which I intend to try my hand at a military box pleat kilt next year, so I will have plenty of left-over material from cut pleats with which to remake buckle tabs (the Glenisla has leather tabs).
But Since this is only a low yardage kilt with very shallow pleats (less than 3 yards in the pleats), is it necessary to cut these pleats first, or could I just stitch the stabiliser on, steek, then stitch canvas down without cutting then apply lining?
The Following User Says 'Aye' to Michael A For This Useful Post:
20th July 17, 10:06 AM
I am very curious to hear what people have to say. From what I have seen of all the different 5-yarders being made out there, none that have seen are cut, nor do any have stabilizer and serious internals. I have been told that this is due to the yardage. Without the cut-away in the pleats and with the lower yardage, the needs of stabilizers, etc. are not there.
Vestis virum reddit
The Following User Says 'Aye' to IsaacW For This Useful Post:
20th July 17, 10:27 AM
I am also curious what the kilt makers have to offer....
Maybe the construction allows the wool to be more stable, but it makes sense to add the usual innards to the 5yd for the sake of longevity. Especially if the kilt is intended to be worn often. I wouldn't think the 5yd pleats not be cut, and perhaps can't anyway due to the stitching/construction. Some canvas shouldn't add bulk at all.
.... (sits and waits to read from those who know)
24th July 17, 08:22 PM
I'm frankly surprised none of them ever responded to this. But from what I've read on this forum, essentially it's the stabilizer that's strapped to your body and the wool just sort of floats over it. So yes, if you want the kilt to last, you can't rely on the wool to take the stress of the straps. I gave my simple 4- and 5-yard RevK kilts a polyester lining inside the 2.5" wide waistband (to which the two primary straps and buckles are attached) to help prevent it from stretching. Not a traditional stabilizer by any means, but I knew if I relied completely on the wool, it would gradually distort from the strain. Whereas I wore each those three kilts two or three times a week for six months, and have so far not seen any indication that they're losing their structural integrity.
The Following 2 Users say 'Aye' to Dollander For This Useful Post:
25th July 17, 07:45 AM
When I make 5 yard kilts, I don't do pleat cut-outs and I don't make a straphole.
I do the inner construction the way I do on 4 /5 yard box pleated kilts..... waist stabilizer, steeking and
3" wide canvas. I do canvas on the aprons, and lining for the aprons and back. I sew a buckle tab on the right hand side to go with the apron strap.
Next I sew the other buckle tab 1" in from the far edge of the under-apron.
Then I sew an inner strap as done for box-pleated kilts.
The Following 2 Users say 'Aye' to bonnie heather For This Useful Post:
6th August 17, 10:41 PM
Thanks Bonnie.
Since this was made with a strap hole rather than a hidden strap/buckle, I will preserve the one that is there. But in all other respects I shall follow your tips.
Thanks again,
Michael
6th August 17, 11:09 PM
The purpose of the stabilizer is to take the horizontal stress of strapping the kilt on. If, when you pull on the buckles you see the kilt stretching and the stress transferred to the fabric or the stitching - Then you need the stabilizer.
If you pull on the straps and see the apron fabric stretching and distorting you need the stabilizer.
The purpose of interfacing is to give vertical stiffness and shape to the kilt. If you can stand the Fell of the kilt up, and it stands on its own, you do not need interfacing. If the Fell does not stand up, then the kilt will hang better with the addition of interfacing.
If when wearing the kilt you see puckering of the aprons then the kilt will hang better with the addition of interfacing.
Together the stabilizer and interfacing allow the outer fabric to drape naturally and swish properly.
The reason for cutting away the fabric behind the Fell is to thin the back of the kilt. If not thinned the back may be overly thick causing sweating and the dread "pillow butt". If the back is already thin enough, due to less fabric as in a box pleated kilt, thinning may not be required.
The reason the internal elements are left out of a low yardage kilt is simply that these kilts are made and sold to be as low in cost as possible. The way the cost is kept low is not just because less fabric need be bought, but leaving out the internal elements saves material and labor costs.
I have always found it odd. Those kilts that do not have the cut-away pleats and the internal elements will still have a liner installed. The only purpose for the liner is to hide all that 'stuff" inside a well made kilt. It is almost like the liner is put in simply to deceive those who do now know how a well made kilt is constructed. (I heard one maker of these kilts explain that the liner was there to keep the kilt clean. To which I could only reply -"Well, if that were true, then the liner would be removable and washable?")
The Following 3 Users say 'Aye' to The Wizard of BC For This Useful Post:
