Results 1 to 10 of 29
    13th July 07
    Madison, WI
    Cutting turnout fabric?
    I had a fireman send me 5 yards of turnout gear fabric to make him a kilt and wow... I am having some terrible problems cutting it. (I know that this is to be expected since it is safety gear and stronger than all get out). I cannot use my rotary cutter, my normal scissors, my leather shears or even the serrated blade. I have managed some crude cuts with a box cutter and my husband tried paper cutters, air snips and finally his metal shears.... and nothing works very productively. The largest cut we can get at a time is with the metal shears and it about 1" each cut (and this isn't really practical for cutting and shaping 5 yards!)
    Any ideas?
    Regina Davan
    2nd May 10
    Roseville, California
    tough cut
    Wow!! That stuff sounds tough Techdragon!
    Perhaps a phone call to a company that makes turnout gear to see what they use in their fabrication ? I assume they may use some kind of giant machine shears for major repetitive cuts, but it seems there must be some amount of small cuts in the garment manufacturing that must be done by hand.
    I wonder how it's going to pleat up?
    Keep us posted!
    kc8ufv's Avatar
    kc8ufv is offline Oops, it seems this member needs to update their email address
    5th August 10
    Toledo, OH
    I am curious how this is going to turn out. I've been around a firestation since I was born, and that stuff is pretty durable stuff. And it just keeps getting better. I'm sorry I don't have suggestions on cutting it, but I wish you good luck.
    8th February 04
    1 Thread(s)
    How about a box cutter, a stack of blades, a mat (used for rotary cutter) and a straight metal edge.
    Lay the material on the mat
    Line up the metal edge (metal yard stick if you have it) where you want the cut
    make 2 or 3 or 27 passes with the box cutter and replace blades as necessary.
    I hope this helps / WORKS!
    4th November 10
    Arizona
    Maybe one of thos black and decker mini saw tools? lol just a suggestion.
    [-[COLOR="DimGray"]Floreat Majestas[/COLOR]-|-[COLOR="Red"]Semper Vigilans[/COLOR]-|-[COLOR="Navy"]Aut Pax Aut Bellum[/COLOR]-|-[I][B]Go mbeannai Dia duit[/B][/I]-]
    [COLOR="DarkGreen"][SIZE="2"]"I consider looseness with words no less of a defect than looseness of the bowels."[/SIZE][/COLOR] [B]- John Calvin[/B]
    2nd October 10
    Dallas Tx
    If it's a kevlar or spectra based fabric you might try putting masking tape on the cut lines ( both sides) and cut it through the tape.
    27th September 04
    Amelia County, Virginia, USA
    If you can't cut, it seems to me that it would be very difficult to pleat and sew. I would also guess that a finished kilt would be very heavy.
    Jerry, Kilted Old Fart.
    30th November 04
    Deansboro, NY
    Good lord, how are you going to sew this stuff?!? Keep us posted!
    3rd August 09
    Fayetteville, North Carolina
    I'm wondering the same thing....
    Quote Originally Posted by Jerry View Post
    If it's that heavy, I'm not sure it will make a very good kilt...how are you going to sew it? That being said, heat is your solution for cutting I think. Being in the Army and doing several modifications to tactical gear and the like, I use an old butter knife that I set on a stove burner and heat it up...and then melt/cut through the nylon. It gives a nice finished edge too. Just don't use a knife you ever want to use for anything else again...because it will be ruined!
    kc8ufv's Avatar
    5th August 10
    Toledo, OH
    Quote Originally Posted by longhuntr74 View Post
    That might work, but I have my doubts. That stuff is designed to easily withstand several hundred degrees for several minutes (a SCOTT pack gives them 20-30 minutes of air) and keep the inside to a (relatively) cool temperature. Temperatures in a burning building can easily reach 1000F
  1. Cutting Back...What about you?
    By bricelythgoe in forum General Kilt Talk
    Last Post: 16th May 09, 10:04 PM
  2. Cutting down a jacket
    By fortcollinsjerry in forum How to Accessorize your Kilt
    Last Post: 22nd April 09, 05:55 PM
  3. Kilt under pleat cutting
    By Rhoderunner in forum Kilt Advice
    Last Post: 2nd August 08, 08:04 PM
  4. Cutting Down a Féileadh Mòr
    By Mechamaniac in forum Professional Kiltmakers Hints and Tips
    Last Post: 29th September 06, 04:22 PM
  5. Damm! We are so cutting edge...
    By KiltedHuntsman in forum Kilts in the Media
    Last Post: 3rd April 05, 08:26 AM
