5th September 20, 12:59 PM
Pleating Wildcat tartan to the sett
Hello Kiltmakers,
I have my copy of TAoK and 7 yards of Wildcat tartan ready and finally (finally!) found the time to start building a kilt. My first very early stumbling block is marking the pleats to the sett. Using the book method, I end up with 8 inches between the apron and the first pleat, when TAoK says it should be 9"-10". Is that still enough?
But also, the pleats I would end up with seem very wide to me. I've used a strip of leftover tartan to try a couple of different markings and test-fold them. I end up with pleats in a size just above 2 inches. Does that make sense? What could I be doing wrong? Maybe someone here has already pleated the Wildcat tartan to the sett properly and can post a picture so I can get a better idea of what I should be doing? I just can't get a good grip on how to get the pleats marked properly at the moment.
Thanks
Hanno
5th September 20, 06:33 PM
Something does sound odd. But, how big are you around at the hips, and what is the size of the sett in the piece of Wildcat that you have? And you have 7 yards of tartan, correct?
6th September 20, 06:51 AM
Hello Barb,
thanks for taking a look at this! My measurements are waist 32 1/2, hips 38 inches, plus 1/2 inch each for future adjustments, and 26 1/2 total length. I am working with 7 yards, formerly double width.
Splits (including the extra 1/2 inch):
Waist apron 17 1/4
waist pleats 15 3/4
hips apron 18 3/4
hips pleats 19 3/4
Looking at the tartan and how I understand the TAoK method, I would mark out the pleats like this:
To me this looks like I am slightly too far apart with the markings. I just now tried to fold the tartan the way I think it would make sense, and then put a marking pin where the center of the pleats would be. Then I get roughly this:
That gives me about 1-inch pleats and a distance of 12 3/4 inches from the center of the last pleat and the end of my front apron flare line. This would be 17 pleats in the whole kilt.
I know I need to be more precise when I eventually start stitching. These were just quick pictures from now, I hope you get the idea.
6th September 20, 07:05 AM
I just took a quick look at this - will write more later, but I have to get an assignment written for my students.
On a glance, this looks totally reasonable to me. Pleat size is going to be on the order of an inch (which is reasonable) - I totally misunderstood your original post because I thought you had said that the pleat size was going to be about 2" (which didn't seem reasonable to me).
More later on the deep pleat! Gotta run ATM.
6th September 20, 07:34 AM
For clarity, yes, I did have giant pleats in the early attempts. The above is already the second try. First attempt looked like this, which happens when you separate the sett into bigger, easier to handle elements:
This, of course, shows the sett better when just laying it out, but it makes the pleats enormous.
6th September 20, 10:59 AM
So, here are the issues with your pinned pleating (pic below):
- The tartan has two pivots, one with a wide tan stripe in the center with double white on each side, and one narrow one with the double yellow stripes.
- You've chosen to split the wide tan pivot with half in one pleat and half in the next. That's fine.
- The center of the pivot with the double yellow must be centered a pleat. The way your pleats are currently laid out, that's not the case. And each time you "get to" the yellow stripe in your pleating, it must be centered.
- Pleats must have mirror symmetry on opposite sides of each pivot. So the pleats I've marked with red must be mirror images of each other, ditto the ones marked in blue, and ditto the ones marked in yellow.
- And you can't have an extra stripe creep in (I put a box around an example, although there are several above) - in other words, the color order must be the same as it is in the tartan without extra or missing stripes, even if the sizes of the color stripes don't quite match the tartan. No one will notice that, but, if you have an extra stripe (i.e., a pleat goes too far into the next color stripe), that will ruin the "to the sett" look of the pleats.
So, you need to pick elements for the pleats so that the tartan pattern is reproduced as faithfully as possible, while keeping pivots centered in pleats (or split between two pleats), having other prominent stripes either up the edges of pleats or in the centers of pleats, and not losing prominent stripes in the pleat taper toward the waist.
Given that you are a trim guy, and the tartan sett is about 8.5", and you have 7 yards of tartan, I would guess that you ought to have 21-23 pleats in the kilt, not 17. That says to me that you should be aiming for smaller elements (maybe 3/4" or so at the hips). If you want some suggestions on how I approach it, let me know.
The Following 2 Users say 'Aye' to Barb T For This Useful Post:
6th September 20, 12:07 PM
The Following 3 Users say 'Aye' to The Wizard of BC For This Useful Post:
6th September 20, 12:14 PM
I know that Barb does not do this but it is one of the teaching tools I use at Kilt Kamp.
I iron a strip of fusible interfacing to the back of my strip of fabric. This holds it and prevents it from distorting over time. It also makes a nice surface to mark on.
Then, when I have my pleating figured out, I will mark the fusible interfacing showing the crease edges of every pleat along its length.
I am not advocating this method. Just offering it as a tip that I found helped new people visualize their pleats.
7th September 20, 11:22 AM
Thank you both! This helps already. I will continue and let you all know how it turns out and if I need additional help!
19th September 20, 09:51 AM
Progress! After a very helpful video call with Barb (thank you!) to figure out the pleating, here's a small but helpful tip that worked for me to get a more detailed "preview" of the pleats for pleating to the sett. After identifying the elements according to the TAoK method (or any other), put a pin in the rough pleat centers so you know how many you will get and calculate your pleat size.
Then, don't just mark the pleat centers, but also use pins to mark the correct pleat width at the waist and hip. This helped me a lot to see the symmetry in the pleating, get the pleat size right, correct small incongruences with the pleat centers and test-fold the tartan to see where pleats land and where the taper will have to be.
I will update with pictures when there is more to see. So far, thanks all, and Barb in particular!
