Results 1 to 10 of 13
    23rd April 06
    Centerville District, Fremont, California, USA, 3rd Rock
    Questions about using canvas duck material
    Hello All-
    I picked up some cotton canvas duck in Khaki color at WallyMart for real cheap.
    Two questions:
    Should I wash this mat'l before I start? It may have sizing in it but it's not quite as heavy as the Carhartt's that I wear @ work.
    Should I add some to the seat measurement so it won't get tight/pull the pleats when I sit? This canvas doesn't give like a wool tartan mat'l.
    Thanks for any feedback you can give.
    Ray S.
    8th November 05
    Fresno, CA
    Quote Originally Posted by bunchdescendant
    Hello All-
    Two questions:
    Ray S.
    YES YES Wash it maybe twice..... as you would wash the kilt (do not use soap) fabric conditioner will help
    Cotton is a whatsit for picking up stains and needing a good hot wash to get them out - and it also shrinks the first time it is washed.
    I would wash the cloth in warm to hot water before starting to make the kilt, possibly several times if it has a lot of size. That will tell you if you are wasting your time with a fabric which is not going to look good as a kilt. Some cheap cottons are more size than fibre and the dye is not fixed, and it really is better to find this out before putting in a lot of effort.
    I would sew along the outer edge of the pleat from waist to hem in order to keep the pleat neat, straight after making the hem.
    For stiff cottons I do not sew the fell, I press the shape in and secure the waist, then sew from the hem upwards for about a foot on the inside fold of the pleat.
    The lower part of the pleat is then fixed at the hip width plus ease measurement, the waist is suppressed but only by the shape pressed into the fabric.
    I have found that using the traditional method of sewing down the fell by hand leads to constant pulls and breaking threads, which might be due to the fabric needing more ease, but it is - in my opinion better to leave off the fell sewing and allow the pleats to move freely as, after much turning and twisting in front of reflective surfaces, the effect is better, on me at least.
    I secure the pleats with hand sewing to get them as accurately placed as possible, and also because I can hand sew using different methods and so secure more layers of fabric than my sewing machine can go through without putting so much pressure on the stack of pleats so they slide out of position.
    Before starting out, do measure your fabric carefully, and be sure that when you start to divide it up you are working on the right edge - one of my first mistakes was to tear a 24inch strip off the wrong edge of the fabric. It was recoverable, that time, but it meant a lot more work.
    When working on plain fabric I use coloured fabric markers, and pins of different designs so I can measure the pleat distance, the separation distance, mark the centres and generally get the folds onto the fabric so I can work on it before putting the pleats in one by one. If all goes well once the pleats are all folded for the first time the kilt is ready for the waistband and belt loops.
    Southern Breeze's Avatar
    Southern Breeze is offline Oops, it seems this member needs to update their email address
    28th August 05
    Chatsworth Georgia, USA
    If you're using a sewing machine use heavy duty needles. I learned this the hard way.
    I sewed the fell on my canvas kilt, but not down low enough.
    HINT: focus on the BUTT measurement. errrr. "hip" measurement, sorry.
    I'm going to make my next canvas or general cotton twill kilt like this.
    1.) I start with plenty of material. Cloth is cheap compared to time when it's only $ a yard.
    2.) work out my "splits" as per Barbs formulas in her book. Round off the splits to the nearest inch, being generous, not skimpy,.
    3.) Cut myself a 28-inch width of at least 6 yards. The selvedge will be the bottom
    4.) serge the raw cut edge, and fold it over 3 inches. Iron that baby down hard
    5.) Allow 2.5 feet for the under-apron, and start pleating.
    6.) Make pleats with a 1-inch reveal, and at least 4 inches of cloth inside each pleat. With my splits I'm going to have about 24 pleats. Or I (read: you) could go for a 1.5 inch reveal and have 16 pleats with at least 4 inches of cloth inside each pleat.. For a canvas kilt, that makes better sense than 24 pleats.
    7.) pleat and stitch the bottom of the fell. By that I mean go one pleat at a time all the way around the kilt but ONLY machine-stitch the bottom one inch of the fell. Just tack that baby down, this is a canvas kilt, don't bother with hidden stitches by hand. work in an even taper on each pleat by eyeballing it, you only want about .20 of an inch, and straight-pin each of them in place. One pin goes into each pleat at the waistband, one goes halfway down the fell.
    8.) Make a BIG reverse pleat...at least 4 inches tucked under at each side, so this is going to eat up material, 16 inches of it. PIN this one, bigtime down the bottom of the fells again. don't stitch it yet.
    Now haul the thing off the table, drop your trousers, and wrap the thing around you. Is it gonna fit around her hiney? If so, cool. If not, then unpin the reverse pleat and add one more pleat, or rip out one pleat until it fits. One pleat one way of the other isn't gonna kill a kilt, and each pleat will buy you 1 to 1.5 inches of room one way or another.
    9). When you've decided it fits, then stitch in the reverse pleat.
    10.) you worked in tapers by hand for each pleat and pinned 'em in. Now I'd go back and work those things, one or two at a time to be drop-dead straight, pin 'em some more and then stitch them down on the machine. When you're done with that you've got your pleats, and they're tapered.
    If your hip measurement isn't 4-6 inches larger than your waist measurement, this isn't gonna work, and you'll have to make adjustment, of course.
    I'll leave the A-shaping, pressing and apron construction to others, but I think this is how I'm going to do the pleats on my next cotton kilt. It'll be an experiment.
    5th January 06
    Manteca, California
    ...cotton canvas duck... Should I wash this mat'l before I start?... Should I add some to the seat measurement so it won't get tight/pull the pleats when I sit?
    I've made and wear both wool and cotton kilts. Second question first - Wool kilts do not "pull the pleats" because they have an undercarriage of special canvas behind the sewn pleats to prevent just that. First question - Yes, wash the cotton material once or twice in warm/hot water, perhaps even tumble it dry, and iron it flat again. Once the kilt is made, you will only wash it after particularly dirty jobs in warm water and let it line dry before touching it up with a hot iron.
    23rd April 06
    Thanks for the info
    Hello All-
    Thanks for all of the input. I have created a binder with all the stuff I have found on the 'Net, so I added the above posts to it. It's getting full of good stuff.
    Now that everything is clear as mud, I think I may be ready to try this. Or am I? Good thing I have a sharp seam ripper (confiscated the wife's).
    OK, off to abuse the washing machine (apartment size) with the canvas (4yds X 60")
    Ray
    "Warning-mouse not found. Click 'OK' to continue"
    23rd April 06
    I finally got the canvas washed
    Hello All again-
    I finally got the other projects done (the job jar thingy) and finally got time to wash the canvas in hot water and used liquid fabric softener. The fabric now has a very nice hand and should do well.
    BTW, the better half threatend bad things if I abused the home washer. Had to go to the laundromat and abuse theirs instead. :rolleyes:
    Did the measurements and I am 5' 9" and 200 lbs. I wear a 36 waist p**ts but the waist @ the navel and the hips both are 40"-go figure. Yup, got no butt. Dad was the same way too. Guess that I just need a little spring-out in the aprons to look right.
    I will post a blow-by-blow pics update as the hacking and sewing begin.
    Ray (suffering from gluteus minimus)
    "There's no such thing as magical ponies!"
    Statement made by pink winged pony
    with crossed axes tattooed on her rump
    You'll need more space than your actual measurements for the hips as when walking you will need space for the movement - otherwise the fell will be constantly flexed.
    This is not such a problem with a more flexible fabric, but with canvas you will need to make the fell wide enough to move inside of, or have your skin try to move under a tight layer of canvas. (ouch)
    Look at what your measurement is when you sit down too - you wouldn't want the aprons sliding backwards and apart too often, which might happen if the fell is too narrow to go round when you are seated.
    23rd April 06
    Let The Mayhem Begin!
    OK people, the cut/pin/sew stuff has begun-I have put a gallery up on my website for all to see. Just don't laugh too hard, OK? There is not much so far, I will add to it as I go.
    http://www.modelautoracing.com/kilt/index.html
    Thanks for all the support.
    Ray
