Results 1 to 7 of 7
jhockin stitch-up bottom of inverted... 26th May 13, 01:07 PM
Chas I believe the answer is yes.... 26th May 13, 02:20 PM
sydnie7 What Barb had to say, a while... 26th May 13, 08:02 PM
The Wizard of BC The little ends of both the... 26th May 13, 09:05 PM
jhockin OK< thanks, everyone ; & yes,... 28th May 13, 09:23 AM
Barb T I don't typically do it,... 1st June 13, 07:13 AM
Barb T This post actually only shows... 1st June 13, 07:16 AM
    7th February 08
    Abbotsford, BC, Canada
    stitch-up bottom of inverted pleat?
    it looks like the bottom of the inverted pleat ( on the kilt I'm currently making) may hang down, below the bottom of the kilt - should I stitch it up, like the deep pleat? ( i can wait and see, but just wondering if this might be something missing from TAoKM?)
    ... should I stitch it up, like the deep pleat?
    19th May 08
    Oceanside CA
    What Barb had to say, a while back
    Not sure which pleats you are describing, but I'd feel free to slightly hem anything that made me go "hmmmmm, I wonder. . ."
    The little ends of both the deep and the reverse pleat do tend to hang below the hem. This is due to the apron taper.
    Both of these "apron tips" should be hemmed up.
    Please see this post by Barb.
    http://www.xmarksthescot.com/forum/s...ad.php?t=40778
    I wear the kilt because:
    Swish + Swagger = Swoon.
    7th February 08
    OK< thanks, everyone ; & yes, I did read all of that, but there does not appear to be anything specifically addressing the inverted pleat, BUT, it does "follow", that if it shows below the bottom of the kilt, them I'll stitich it up - later
    30th November 04
    Deansboro, NY
    I don't typically do it, because it doesn't typically hang below. But there's no reason why you can't if it does stick out.
    30th November 04
    Deansboro, NY
    Both of these "apron tips" should be hemmed up. Please see this post by Barb. http://www.xmarksthescot.com/forum/s...ad.php?t=40778
    This post actually only shows turning up the deep pleat, not the inverted pleat. The inverted pleat is typically shallower than the deep pleat and, hence, is less likely to show. But, as I said above, there's no reason that you can't stitch it up if it shows. I've never had an issue with it, actually.
