Results 1 to 10 of 18
    14th March 14
    Somewhere in the flat, dusty Texas Panhandle
    Difficulty Repressing the Pleats
    For the past three years, apparently, my pleats have looked like a shower curtain, and I have recently attempted several times to repress them. Unfortunately, I can't seem to do it quite right . Methinks the issue lies in the way I lay it out to press. Whenever I lay it out on the table (over a towel) it looks like an "A" or "/ \". I believe the way it should look is a box, correct? When I attempt to lay it like that, it becomes very wavy, strange looking, and difficult to manage. The waistband also curves -- is this normal?
    In the past I have taken it to be dry-cleaned and pressed, compleatly (pardon the pun) unaware of the incorrect methods they were using.
    I need help, O Wise Rabble!
    ~Live Long and Piobaireachd~
    Jordan "Grip" Langehennig
    Kerrville, Texas
    8 Post(s)
    To press it, obviously, you don't want anything buckled. You'd want to lay it out flat with the aprons at each end. When laid out like this, yes, the waistband will curve and so will the bottom. This is due to the tapering in the fell area. The amount of tapering (and thus the amount of curvature) will be unique to each kilt and how it was made to fit the person. But in general, when a kilt is truly laid out flat so the pleats can be pressed, it will look a lot like this:
    *edited to add: Your kilt may need to be squared up a little if the pleat lines have wandered over time. Hard to say without seeing it. But also keep in mind that when you press a kilt, it's best to get all the pleats exactly where you want them and then baste them before pressing. This is why most new kilts come with basting stitches still in them.
  3. The Following 5 Users say 'Aye' to Tobus For This Useful Post:
    30th March 05
    Kentucky
    As Tobus said, the pleats will taper from waist to hip in the fell area. There should be no taper below the hips; the pleats should be straight and parallel from hip to selvedge.
  5. #4
    2nd May 10
    Roseville, California
    I may be wrong, but in an earlier post about your kilt pleats, it looked like your kilt was made of very light material. I remember some saying you may have a hip dimension issue with your kilt. Having the hip measurement too large will cause the material to hang like curtains with waves in it as you are forcing too much material below a set waist circumference. The material has to go somewhere, so it folds back in on itself in waves. Having too light weight material can have a similar effect, as the weight of the material will not pull down on itself enough to resist the lateral wave potential. Either of those issues or, worse yet, both issues combined and you have a problem no amount of pressing will cure.
    Just want to be certain you are trying to fix the right problem.
    Best of luck!
  6. #5
    I happen to be basting a kilt in preparation of pressing so thought I would post some photos for you.
    I hope these help.
    If you just flop a kilt down on the table the Fell area, (That part in the back that is sewn down and tapered) will try to lay flat, but the pleats themselves will splay out.
    You should be able to see that the pleats are not the same width at the hem as they are up at the bottom of the Fell.
    The waistband is taking that curve you mentioned.
    To properly lay out a kilt for pressing you must insure that the pleats are the exact same width all the way down their length just as they are at the bottom of the Fell.So we lift the Fell area up till the pleats lay perfectly straight and
    parallel
    I have a rolled up kilt holding the Fell area up. This allows the pleats to lay flat
    .Here you can see two lines of basting in place. The pleats are held parallel by the basting.And here you can see why we use basting thread instead of pins.
    You should be able to see that the basting thread lays flat while at the pins there are pronounced bumps. If you were to try to press over the pins those bumps would be transferred to the pleats.
    These two lines of basting took about 10 mins. to put in.
    I'll now put in a third where the pins are and then PRESS, not iron. You use the heat of the steam to heat up the fabric. This softens the fibers.You then press straight down with pressure to set your creases. Then pick up your iron and move to the next spot.
    I wear the kilt because:
    Swish + Swagger = Swoon.
  7. The Following 2 Users say 'Aye' to The Wizard of BC For This Useful Post:
  8. #6
    14th March 14
    Thanks, Mr. Wizard.
    I'm pretty sure my problem is the hip dimensions. How difficult is this to fix? I certainly couldn't do it, but a local former member of the Black Watch and kiltmaker may be able to.
  9. #7
    26th February 12
    Lake in the Hills, IL
    38 Post(s)
    1 Thread(s)
    The kilt cannot be repressed, it is simply too mirthful!
    All joking aside, if the waist is correct size I would imagine re-tapering is a possibility but a darned good bit of work...
  10. #8
    24th September 04
    PiperofthePlains,
    Please see this tutorial to determine if your kilt is the size you think it is.
    http://www.xmarksthescot.com/forum/s...ad.php?t=81662
    Forum Owner
  11. #9
    22nd May 08
    I hope these help.
    parallel
    And that, Ladies and Gents, is why he is THE WIZARD
    Victoria
    Just because you are paranoid doesn't mean they aren't out to get you.
  12. #10
    24th September 04
    PiperofThePlains,
    About having your Black Watch friend work on your kilt.
    It will all depend on who made the kilt in the first place. If you kilt is made in the Regimental style that your kiltmaker learned, then yes, he could probably fix it.
    If your kilt was made with a different method he may not know how to fix it.
    All you can do is ask him.
    Forum Owner
