Kilt Damage From Cheap Sporran Clip
A lot of folks here probably already know this, but in case anybody else new to the kilt and accessories hadn't thought of it, I thought I'd throw this out there.
I pulled out my SWK Heavyweight wool and noticed what you see below. This happened after a 1 hour outing some time ago and I didn't notice it until now. I generally try to make sure the clip openings face away from the fabric, but I must have missed one that last time. I hate to think what would have happened if this would have been a day long hike.
I think I can repair the damage easily enough, and in any case, this area will always be covered with a sporran, but I'll always know that it is there. Anyway, I have replaced my cheap clips with better ones that I picked up from Sears, shown below. I would have preferred trigger clips, but they didn't have any that were small enough for my taste.
Whether using cheap clips or better quality clips, I would recommend doing what I do on my ceramic fishing rod guides before each use to check for cracks... Drag a cotton swab along every edge you can find, with a bit of pressure. If it snags, get some fine sandpaper, needle file, or small whetstone, and knock off the offending sharp corners and burrs. If the metal can catch the cotton, it is a good bet that it can snag your kilt. And don't forget to check your split rings, chain links, D-rings, or whatever else may rub on the material.
An ounce of prevention and all that.
Might want to check the edges of your SWK buckles too, might damage the leather straps. I had to sand and buff mine out.
Another good reason to run a sporran strap
Forget the clips and get yourself an all leather sporran strap.
Regards, Bill McCaughtry
I agree. That's all I use.
Repeating two words for further emphasis:
Sporran strap.
Me too. I don't use chain anymore either.
Edit: Stillwater's Sporran Strap
What they all said.
A one piece sporran strap (yank the D-ring out of the back of your sporran) is worlds more comfortable and convenient than a chain strap.
Just make sure to get a decent one where the edges have been beveled and smoothed over, or you'll get wear all across the apron.
ith:
I have a couple of homemade straps, and my Stillwater strap should be delivered today, but I still occasionally enjoy wearing a chain or hangers, and didn't want this to happen again. Also my son can't possibly wear enough chain on his body, so he has new and overhauled clips now.
Just something I wanted to toss out there so this doesn't happen to somebody else.
Right on, Bugbear. Mine do need a bit of polishing as they like to grab the straps. Something to do tonight.
18th May 11, 05:00 AM
Yeah I noticed snagging the first time I tried mine on. Turned the clips, and then bought a cheap narrow black belt for a really large lady from WalMart - $15.00 It's more comfortable, looks better in my opinion, and creates no wear whatever. I even wear it for dress occasions now just because I like it and trust it. The sporran also hangs better and flops around less. I plan to pick up a couple more.
Thanks for the warning about the edges though - that's important too!
By chrisupyonder in forum Kilt Advice
Last Post: 9th April 11, 09:37 PM
By McJore in forum General Kilt Talk
Last Post: 8th November 07, 10:36 AM
By cgrinder in forum General Kilt Talk
Last Post: 12th December 06, 12:43 AM
By setboy in forum How to Accessorize your Kilt
Last Post: 29th October 06, 11:10 AM
By bubba in forum Kilt Advice
Last Post: 1st October 04, 07:19 AM
