Results 1 to 9 of 9
    Another DYI Flashes Tutorial
    I remember that there was quite a discussion on making flashes at Kilt Kamp.
    I, of course, do things slightly different from Barb but basically the same. Not wanting to hijack her flashes tutorial I thought I'd show you how I do them.
    We all do things a little different and so should you. Experiment, have fun.
    Here are some shots of some matching flashes for a Kilt in the Nova Scotia Tartan.
    I use a fusable non-roll waistband interfacing. It is exactly 1 1/4" wide so it gives a good clean fold. Laying it directly on the fabric allows me to layout on the diagonal easily. Lay it out, then iron it down.
    The interfacing I use is stiffer than the what Barb uses and I think I'm going to try some of hers.
    here's a shot folding over the fabric on the back side. I then use stitch witchery fusable to hold it down.
    Another shot of the folds on the back side.
    One of the different things I use is black fusable wiastband interfacing for the back side. This is known as "Jiffy Waistband" and is perforated in the middle to make it fold easy. I just cut or rip it down the middle and use one half. I think if gives a good looking clean appearance to the back.
    I then use the corner of a drafting triangle to cut the notches. I do the cut with an Olfa circular cutter and finish them with scissors. Then a touch of Fray check to seal it up.
    Then sew down the tops for the elastic.
    A little trick I do is to sew a small bartack at the top and bottom of the elastic loop. It helps keep the flashes straight and together.
    The finished product.
    I wear the kilt because:
    Swish + Swagger = Swoon.
    Show Off!
    Steve,
    Actually having the tartan on the bias like that really looks good.
    6th December 06
    Michigan
    Very nice! Thanks for the great instructions!
    16th July 06
    Sierra Vista, Arizona, USA
    I guess I'll be pro-bias also. It is much easier than trying to make sure that everything is exactly plumb and centered. Thanks for the inspiration. O'Neille
    20th December 04
    Charlottetown, PEI
    oh those are sweet! i love them like that!
    15th April 07
    State College, PA
    Yes, the bias it the boss.
    2nd July 06
    Madison, Wisconsin
    It looks better on the bias, I'll agree, but it also requires more tartan, which makes me sad.
    5th August 07
    That looks.. just.. awesome. I simply must try this. Thanks for the directions.
    5th November 07
    Vailly-sur Sauldre, FRANCE
    Excellent work !
    Robert Amyot-MacKinnon
  1. Flashes
    By Celtic Amazon Goddess in forum General Kilt Talk
    Last Post: 29th March 07, 03:15 PM
  2. DIY flashes help
    By neo71665 in forum DIY Showroom
    Last Post: 17th December 06, 08:28 PM
  3. style question - tartan flashes, solid flashes or no flashes?
  4. Your flashes
    By Jewddha in forum How to Accessorize your Kilt
    Last Post: 1st May 06, 05:44 PM
  5. Possible Flashes?
    By pdcorlis in forum How to Accessorize your Kilt
    Last Post: 17th January 06, 09:13 AM
