Found a pin at a garage sale for under a buck and decided to replace the charms on with more to my liking. Simple project, I'll admit, but I figure there isn't one quite like this out there anywhere else. As found: 1185722_612735722112029_2141398798_n.jpg My charm -- an old bagpipe pin with the studs removed: 1186731_612735765445358_1810729595_n.jpg Copper wire around the middle tenor drone, coil spring above that. (And a few inches of dental floss, just in case the metal fatigues.) 1173778_612735818778686_340431913_n.jpg On display: 561540_612736155445319_1614726025_n.jpg
Chainsaw02,TJ Kelley
That is just cool!
Rob, ClanMacMillan, NM
That is a great idea
Member of Clan Hunter USA, Maternal - Hunter, Paternal - Scott (borderlands) Newly certified Minister. If you cannot fix it, mess it up so bad that no one else can either.
Quite clever - good re-use!
View Tag Cloud
