28th December 07, 11:54 PM
Could Have Been a Sgian
After jmercier and Panache showed off their sgian like knife building skills I thought I'd share this. In reality it could be a sgian.
An Army friend of mine gave me a complete six point deer mount and an eight point shed for future sgian projects. He expressed interest in getting a knife and I offered him a choice of some blades I had lying around. He chose this one even though he could have gotten a sgian (it's deer season). I decided on moose scales, plain brass pins, no liners, and a decent finished size. He's got some big hands so I used a good size chunk of moose antler.
The finished knife is 6.25", blade is 3.5"
Here are the basic components. One old unknown blade with a great edge. Some bullwinkle and a couple of pins.
Rough shaped with pins holding it all together. I taped the heck out of the blade because it was already very sharp. I have a piece of kevlar tape I put under the masking tape.
Checking the fit to my hand. The new owner has even bigger mits.
A finished useable knife.
Finally, I made a heat molded plastic sheath that can accomodate a 2 inch belt. The finger hole holds it perfectly.
The final finish is just 1000 grit then some grey rouge on a wheel. A spot of hand rubbed beeswax and buff.
29th December 07, 02:07 AM
Kresent, do you epoxy and pin, or just pin alone?
How do you hold everything together when you pound the pins?
29th December 07, 02:27 AM
I fit one scale, clamp and drill through the tang. Insert the pins on one side. Fit the other scale and clamp. Remove pins one at a time, drill and replace pins through both scales. With a friction fit I rough shape the handle. When I'm close all around I remove the scales and pin them together to true them up on the sharp end.
I then epoxy the scales and pins in place. When the epoxy is set I do the final shape and poish. Depending on the material, I may use pins, cutler's pins (threaded), or just epoxy. As this is a knife that will see some heavy work I elected to pin it. On large full tang knives I always use cutler's pins.
I have an aircraft rivet gun. I just filed these pins down and finished them with the the gun and a die. This isn't a required step. On smooth finished knives you smooth and polish everything.
29th December 07, 02:34 AM
Thanks for the details.
As always, you do great work. Hope to drop in some day.
29th December 07, 02:57 AM
That blade looks like what they called a finger knife. I believe they were made by Gerber. They were great small knives for skinning. Yours looks much better than the original though.
Jerry, Kilted Old Fart.
29th December 07, 09:18 AM
Based its size it could be a sgian dubh.
Nice work as always O'Neille. I have to get brave and try to make a knife with scales.
29th December 07, 11:25 AM
Wow very nice work..is there anything you can't do??
Sara
~Christopher Morley
29th December 07, 12:01 PM
Sara
Yes, I can't sit around doing nothing. Even when I'm doing nothing, I'm thinking about things to do.
I may have to change my signature line.
30th December 07, 09:32 AM
Boy, that's the story of my life!
Great knife. Thanks for posting.
30th December 07, 09:42 AM
Very nice work on it, it's quite an improvement.
By McMurdo in forum How to Accessorize your Kilt
Last Post: 7th August 07, 03:49 AM
By Raptor in forum DIY Showroom
Last Post: 9th May 07, 07:08 PM
Last Post: 27th April 07, 04:08 PM
By neo71665 in forum How to Accessorize your Kilt
Last Post: 11th March 07, 01:41 PM
