23rd January 07, 05:30 AM
23rd January 07, 05:31 AM
"Durum Patientia Frango" (By patience I break what is hard) Clan Muir Muir motto
"Do well, and let them say - Gordon!"
"I don't care to belong to a club that accepts people like me as members" My hero, Groucho Marx
23rd January 07, 05:36 AM
That looks great, I really like the key anchor idea.
23rd January 07, 06:14 AM
Looks good. I like how the tab that holds the chain for the closure also holds the key clip ring.
So, you found and used the post closure . . . how easy is it to fit and use? I've thought of using one, but don't know if it would be difficult to attach in creation or for day-to-day usage. It should be secure (as long as you avoid headstands, not a good idea kilted anyways). Where did you get your's? How was the customer service/price/quality balance?
For Ron's behalf:
What was the dimensions in inches (or metric if that is what you use, though most of us Americans don't have any idea of what that would mean)?
Looks good and will look good on ya!
23rd January 07, 07:50 AM
I like it. Kind of a retro late 60's early 70's feel to it.
Adam
23rd January 07, 07:59 AM
A simple yet handsome looking sporran. You should be proud.
Well done.
23rd January 07, 08:16 AM
Damn fine job! makes me ashamed of mine.
23rd January 07, 09:41 AM
Looks nice! I really like that closure system.
23rd January 07, 10:02 AM
A good looking leather you've used there Hachiman. Very neat job overall and a good shape, well done. Did you glue the lining? How'd you affix the female part of the catch? And are you going belt or straps/chain?
23rd January 07, 04:00 PM
Questions answered
The post closure cost me $12.50 from my 'local' tannery (Packers Tannery, Burpengary, QLD)...I always go there for my supplies, even though it means driving past 2-3 retailers to get there. I get a discount for being involved in a medieval re-creation group, and I get good service every time.
As for ease of fitting, the post closure isn't too hard to fit. It requires two rivets (I use cold press rivets, not pop rivets) and some careful measuring to make sure it's aligned properly. The down side to the post closure is, because of the thick base of the female part of the system, there's a 0.5 cm thick plate on the inside of the sporran now. I'll cover that with more of the material that was used for the lining.
Also, due to the two layers of leather, I had to enlarge the hole a little. I think that was more a problem with the closure, actually, because even when it wasn't fitted, the post only went thru the hole about a third of the way before it jammed tight.
For Ron's behalf:
The pattern was designed around an 8" diameter circle. I used a thin but stiff cardboard, and a compass and pencil, to scribe a circle, and then drew a 'centre-line' around which all other parts of the pattern were based.
Yes, Ozmeath, I did glue the lining - pinwale cord. The female part of the catch pokes thru a hole in the front shell of the sporran, and the plate is held in place with rivets. I'll see if I can get a pic to help illustrate what I mean. I'm going to start work on the straps next - I've got a strap-cutter, and enough of the same leather used in the sporran to make some straps. I'll soften the leather with "GEE-Y" after I dye it but before I seal the leather, which should help them to conform to my body when in use.
To everyone else, thanks for the positive feedback - it's nice to get the approval of one's peers!
cheers
Hachiman
Reason: Oops, I forgot to answer a question.
Pro Libertate (For Freedom!) The motto of the Wallace Clan
When injustice becomes law, resistance becomes duty.
By haukehaien in forum DIY Showroom
Last Post: 28th December 06, 08:02 AM
By H. Hastings in forum DIY Showroom
Last Post: 18th December 06, 12:42 PM
By Kilted Taper in forum Show us your pics
Last Post: 4th December 06, 06:51 PM
By Kilted Taper in forum DIY Showroom
Last Post: 3rd December 06, 10:22 PM
By cormacmacguardhe in forum Miscellaneous Forum
Last Post: 29th August 06, 07:05 PM
