29th October 12, 12:28 PM
Home made Targe, Dirk, Sgian Dubh and Sgian Achlais
Hey all,
over the last couple years I've become very interested in all things Jacobite(specifically the 45). After pricing all of the things I would like to have I found out I wasnt having any of it unless I won the Lotto or made it myself. Due to the unlikelyness of the first option I figured "what the heck, Highlanders made a lot of this stuff with little resources, I bet I can do it too". So I got to it, learned how to harden a blade, temper it and even got a little crazy with decorations.
You'll notice the heart theme. When I was in the Army(101st Airborne, 502nd Infantry), our regiments symbol was a black heart. We wore a patch on our helments and painted it on our HMMWVs. I have seen a lot of "Jacobite era" stuff with hearts on it so it seemed destined.
On to the pictures........
First, is my Dirk.
End cap made of brass. Hard to see but its a heart.
Next is the Sgian Dubh. Nothing reall spectacular about it but figured I'd show it.
I'm really interested in the Sgian Achlais. I have seen several on the internet and just had to have one.
Should have mentioned that all of these knives are full tang. I think I may have made the first full tang Dirk! I have never seen another, any way.
I bought the steel at Home Depot, it was about two inches wide and fairly thick. Seemes to be fairly high carbon steel as it will hold a good edge after hardening. I drew the shape onto the blank steel and then cut it out with an angle grinder. Hardened it, tempered it and then sharpened. A lot of work but also a lot of fun.
More to come..........
Reason: added info
Somebody ought to.
29th October 12, 12:38 PM
29th October 12, 02:47 PM
I like the Targe, particularly the back of it. All good stuff.
KD
30th October 12, 06:18 AM
Thanks for sharing these photos!
I noticed that your targe has a strap, presumably for carrying over your shoulder. I've been thinking of doing the same on my (future) targe project. Either that, or making some sort of other attachment point where I can hook it to a baldric. Is a carrying strap normally seen on a targe? I haven't looked at enough of them to know.
Also, since you used 3/4" plywood, I was wondering what you thought about the weight of it. Does it seem overly heavy? Would you mind putting it on a scale and telling me how much it weighs?
30th October 12, 08:04 AM
Tobus, yes that is an over the shoulder carry strap. Most of the Targes I have seen or read about had a strap to allow the user to carry the Targe when not in immediate use.
The ¾ inch thick pine plywood is way too thick and heavy. I don’t have a scale but imagine this Targe weighs about 6 or 7 pounds.
Targes were originally made by glueing two thin sheets of oak together at a 90 degree grain angle. This made them light weight while still remaining strong. The first Targe I made was with ½ inch thick oak plywood, found in the cabinet section of Lowes. They come in 2’ by 2’ squares which leave little to waist after cutting the circle out. They are easy to cut and very easy to hammer the tacks into plus is a little more historically accurate. Oak plywood is much better.
I wasted numerous tacks with the pine plywood before pre drilling the holes and then I had to put glue on the tacks to keep them in there.
Somebody ought to.
31st October 12, 05:06 AM
Somebody ought to.
23rd January 13, 11:34 PM
I use 3/4" plt wood for all of my shield projects and I don't find them heay at all. Of course since I normally do the 13th century thing, they are mostly heaters. I too use the 2'x2' dimentions, which are better for the foot combat that my troop does (historical dimentions similar to this can be found in art from the period). I highly recomend shoulder straps if you plan to be marching or walking for any length of time without fighting. I have tried attaching the shield to other belts and what have you but I find a separate strap alows one to carry it opposite of the sword or across the back thus evening out the weight a bit. They aren't that heavy on their own, but once you add the other parts of the kit all in one place and start walking for a bit, you will notice it.
Keep your rings charged, pleats in the back, and stay geeky!
https://kiltedlantern.wixsite.com/kiltedlantern
1st February 13, 06:44 PM
Nice work, I like the part of sparring with your daughter, good for both of you.
I may try my hand at this targe project, for my son and I.
8th February 13, 05:16 PM
The targes I saw as a child all had a spike in the cup,, what saythe rabble
8th February 13, 07:20 PM
I actually really like the Sgian Dubh.. I like its' simplicity and form. I've done a bit of tempering and sword polishing. That's a great project. Thanks for sharing.
