13th November 06, 11:35 AM
Jacket conversation explained
The following photos will, I hope explain how I convert my Jackets.
This picture shows me measuring the the jacket to length, for me it is twenty four & a half inches plus one & a half inches for the seam. It will vary from person to person, I measure from the bottom of the collar of the jacket to the bottom to the sewn part of the pleats on the kilt. (26" for me)
cut it to your size(26" for me). I have already cut this jacket. Dont worry about the sporron curve at this stage, just cut the whole length of the jacket, measuring from the bottom of the jacket up to your correct length along the jacket to give the excess.
This photo shows me marking out the sporron curve, I do this free hand until it looks right. I start from 1" below the button & draw to the finish length of the jacket( 24 1/2" for me
Measure one & a half inches below the curve to give a seam. this matches up with cut length of the jacket ( 26") for me. Cut the excess material from the bottom of the curve
It should look like this
Remove the pocket flaps & move them up so that they just cover the opening
Reattach them in this position after sewing up the opening ( they become false pockets)
Some of the material off the bottom can be used to make epualets if required
The finishing off, turn the seams over to the finished length along the bottom of the jacket & pin, leaving the lining hanging down. Sew along the jacket then cut the lining to suit.
The curve is a little more trickey, it is better to use bias binding, attach it to the outside of the jacket along the curve, then fold over & cut off excess material leaving only 1/4 " & then attach the other end of the bias binding to the inside of the jacket, this will give you a much better curve.
I know its long winded but I hope it makes sence
13th November 06, 11:52 AM
It makes perfect sense to me. I'm glad you posted pictures of your method.
I like how you handle the pockets. Up until now I have been making patch pockets to cover the slash. I'll have to see which way I like better now.
Thanks!!
13th November 06, 02:20 PM
Thanks for posting the pics, David, very informative, though I don't think I'll try this at home as I'm not exactly a skilled seamstress.
13th November 06, 03:46 PM
Thanks David .A picture is worth a thousand words
13th November 06, 05:09 PM
Thanks for the illustrated instructions. Before seeing this it all seemed so daunting. Good job, David.
13th November 06, 07:54 PM
You presented that very well. I am tempted to do one of my own.
13th November 06, 09:03 PM
Very clearly explained, David. Do you have any pix of the bias binding process in the curve? That can be tricky.
13th November 06, 09:42 PM
The pics explain it well, thanks.
Sorry, but I'm a tad slow and can't track the radius/bias binding part for the sporran cut out.
Maybe next jacket you could share pics of that too.
Thanks
Ron
13th November 06, 10:31 PM
By Canadian_Kilt in forum General Kilt Talk
Last Post: 17th December 06, 08:01 AM
By David Dalglish in forum DIY Showroom
Last Post: 13th November 06, 10:31 PM
By Blu (Ontario) in forum General Kilt Talk
Last Post: 25th September 05, 03:16 AM
