18th January 08, 04:44 PM
Kingussie in Multicam?
Okay, Cloves' recent thread on paintball and my yearning to keep my mind occupied over the next several weeks of deep freeze. I re-evaluated my paintball gear and my need to get every tactical advantage in the field as my own players have a tendancy to shoot me in the back. After much research I've gone ahead and ordered all my gear in Mutlicam:
I seriously thought about making an X-Kilt out of the fabric I also ordered but I'm interested in the reverse Kingussie. Although there are some wisdom embedded in his forum (thank you Pleater). I hoping to explore more of this pleating style and also to mke it as easy as Alan H has made the X-Kilt. Where do I start, is there any interesting links out in cyberspace, is it do-able as a first kilt?
Reason: Spelling errors
18th January 08, 04:49 PM
Been wondering what one would look like in Multicam. Made one in USMC Digital woodland (MARPAT) and am planning one in Desert MARPAT for a forum member.
Maybe I'll make my uncle who hunts a blaze orange one in thick flannel or wool blend.
18th January 08, 04:50 PM
Perhaps for your first kilt you should tackle an x-kilt, maybe with a different piece of material so that you can save it for after you've got the hang of it. The other plus to this is that you will have more kilts and it will be about as economical as you can get, also you would have the pride of knowing that you made them yourself.
18th January 08, 05:28 PM
My first good one was my 3rd Xkilt
18th January 08, 05:57 PM
 Originally Posted by ccga3359
...I'm interested in the reverse Kinguisse.
Where do I start...
Grant, this is where I got started back in 2002:
http://www.kiltair.com/kilt_making.php
This page has links to four different set of instructions, but the one on the upper right (Modern Kilts) is your best bet. It shows Jan working with tartan, but I worked it with cotton upholstery material. (Click "Comments" on the far left blue border - the first comment and pic is me.) The point of this initial exercise is to wrap your head around the "geometry" of a kilt. Jan's illustrations are pretty good and the instructions work with poly/cotton camouflage.
Barb's book does the same thing, but it is extremely detailed, focuses on traditional methods, and is geared specifically for wool. I came across The Art of Kiltmaking after making my first couple casual kilts and wanting to step up to wool tartan.
Follow Jan's instructions for the apron, the deep pleat, and one-half of the pleats following - as far as the center back. Leaving his instructions, the pleat on just the other side of the center faces the other way - and the two pleat edges touch, forming the inverted box pleat. Make these reversed pleats for the other one-half of the number, then another deep pleat under the underapron. The two halves of the kilt are mirror images of each other.
JUST FOR FUN - and before sewing anything - lay the fabric out on a table and at about hip level (approx 15 inches up from the selvedge) try folding and pinning both aprons, the deep pleats, the right-facing pleats, and the left-facing pleats. For the pleats, chalkmark the fabric every six inches and fold the pleats to reveal two inches and hide four. This exercise doesn't have to be done to your own hip measurements, but you could try.
Lay your hands on a Utilikilt and see how they do it (because they use the inverted Kinguisse style)... or I could send you the Pink Death camo kilt to use as a reference.
w2f
18th January 08, 06:07 PM
Grant, take a good hard long look at your RKilt. There's your example of a reverse Kinguisse. And an excellent one at that.
Next, follow W2F's directions above.
Third, if you want, I'll loan you my first edition The Art of Kiltmaking on Friday.
18th January 08, 06:17 PM
w2f
Errr, Thank you. It's the cut I like, the pattern I like, the idea I like but I want to blend in and not be seen.
Yes I realize that my RKilt is this style and I was thinking of tearing it apart to see how it's made...
Thanks also Gary, I have Barb's book and was considering using tht as reference with Alan's X-Kilt excellent instruction. No where do I get camouflage thread?
19th January 08, 08:54 AM
Dee
Ferret ad astra virtus
19th January 08, 11:07 AM
oh jeez....don't tear apart an Rkilt....that's sacrilegious oe something.
Multicam is cool....and the more i think about it, a kilt is very much like ghillie...in that it hides the outline of one's legs. I might have to consider kilted paintball as well.
19th January 08, 11:36 AM
Believe it or not - ..here..
Last Post: 6th November 07, 01:48 PM
By Pleater in forum DIY Showroom
Last Post: 2nd June 07, 09:26 AM
By Pleater in forum Professional Kiltmakers Hints and Tips
Last Post: 1st September 06, 02:04 AM
