Results 1 to 10 of 12
    4th October 07
    Charlotte, NC
    Poly wool blends
    has anyone experiance with a poly wool blend? its not on that material comparison chart on the left column so i have no idea what to expect? hold does it hold together, is it comfy and how is it verses other material?
    Gillmore of Clan Morrison
    If you think about it, a poly-wool blend would be almost impossible to characterize for the chart because of the huge variety of poly-wool blends available to the consumer. How much poly-viscose to how much wool? 50/50? 20/80?
    25th May 06
    Kitchener, Ontario, Canada
    A lot of Polyester-wool tartans are 55/45.
    [B][COLOR="DarkGreen"]John Hart[/COLOR]
    Owner/Kiltmaker - Keltoi
    4th October 07
    Charlotte, NC
    yeah it was 55/45, is that the ratio of poly and wool?
    23rd April 04
    Forest Grove, Oregon
    I have made a couple of kilts medium weight 55/45 wool blend and had no prolems. it is easy to work with and does not wrinkle to speak of.
    It is a good material to use.
    4th October 07
    Charlotte, NC
    ok. cool, that good to know.
    7th July 06
    Roswell, Georgia USA
    So if you get a hot coal on it only half the threads will melt?
    15th April 07
    State College, PA
    Quote Originally Posted by turpin View Post
    and if you splash bleach on it only 45% will disolve.
    29th January 06
    Asheville, NC
    I've only had experience with the 11 ounce poly/wool from Fraser and Kirkbright, and i like it. It's light, but works well and holds a pleat without edge-stitching. Excellent for hiking kilts as it is light weight, warm, and dries quickly, and the tight weave resists snagging far better than polyester (acrylic) twills.
    12th November 07
    NC
    So is one half in the back on the kilt or on the front?
  1. F&K remnant 11 oz Poly/Wool advice?
    By Perldog007 in forum DIY Showroom
    Last Post: 5th September 07, 09:51 PM
  2. 65 Wool 35 Poly Pleating?
    By gilmore in forum Professional Kiltmakers Hints and Tips
    Last Post: 8th November 06, 07:36 PM
  3. My BW Wool/poly Hiking Kilt
    By O'Neille in forum General Kilt Talk
    Last Post: 4th September 06, 09:33 AM
  4. Wool or Poly?
    By Calico Jack in forum Contemporary Kilt Wear
    Last Post: 22nd May 04, 07:18 AM
