10th December 16, 08:20 PM
Self-made kilts so far...
Now that I posted my refurbished sporran, I suppose it's high time for some pics of the actual kilts I made.
I made this denim one a couple of months ago, mostly by examining and copying the construction of my existing utility kilts (though the pleat taper formula from the X-kilt instructions did come in handy ). However, I decided to go with a single side strap, along with the buckle from a trouser belt that'd fallen apart, as well as including a fringe. I also added a slight slope so it'd be less likely to ride up in the back, since I wear it closer to my trouser waist. It did have attached pockets originally, but one disintegrated in the wash so I removed them and just use the detachable pockets shown here (at least in situations where a sporran would get in the way, e.g. at work):
My original plan was to go with polyviscose next, and even ordered a whole bunch of swatches from Scotweb to help me decide. But an early cold spell inspired me to instead skip the PV and go straight to 16oz wool. My mother and sister gave me money for fabric for my birthday, and it was enough to buy two meters each of Murray of Atholl Ancient and Murray of Tullibardine Modern:
As you can see, they're the same style as the denim one. I'm not really sure what to call them; I refer to them as "American-style" in my profile, since they've that same shallow, RevK pleating, narrow apron, and wide waistband that's the norm for utility kilts while lacking the actual utility part (i.e. attached pockets). I would say contemporary kilt, but that's what Steve Ashton calls his that still have the traditional deeper, single-direction knife pleats. And while I do know of one company that refers to their tartan utility kilts as hybrid kilts, I've seen that most often referring to box pleat kilts that are primarily a solid color with tartan for the inside pleats. Hmm...maybe I'm overthinking it and should simply call them "kilts".
I finished these much more quickly than the denim one, not only because I'd done it before but because the selvedge and the lack of a need to stitch the pleats meant there was a lot less sewing. On the other hand, there was the issue of sewing on the straps (and in the case of the Atholl kilt, the leather buckle tabs, as the non-tabbed buckles had yet to arrive from Kilts Wi Hae). I wound up marking the points for the holes with a pin, then putting the denim needle in my sewing machine and using it like a mini drill press to manually punch the holes in the leather so I could sew them on.
Note that I made no effort to match the pattern with the belt loops and tabs, but rather just chose a portion of the tartan that formed an aesthetically pleasing pattern. I likewise had to get creative with the pleating, since there was no overlap so pleating to the sett or stripe was out of the question. The Murray of Atholl has a 13 inch sett, while the Tullibardine's is 9 inches, so dividing them by 6 and 4 respectively gave me 2 1/4 inch pleats. So the Atholl is pleated to the semi-stripe, while the Tullibardine is what I've come to call the pseudo-sett:
I know that this'll make the purists wince, but when I pinned the pleats, I didn't measure but rather simply eyeballed it. Sorry.
And of course, I made matching flashes. Yes, I suppose the fringed denim flashes are a bit much; I guess there's a tiny part of my brain that will forever reside in the late 80s...
In case you were wondering, the tartan behind them is MacCallum Modern (my surname is Murray, but my great-great-grandmother was McCallum), from which I'll be making my next kilt soon...
The Following 3 Users say 'Aye' to Dollander For This Useful Post:
