Results 1 to 10 of 14
    Harold Cannon's Avatar
    Harold Cannon is offline Oops, it seems this member needs to update their email address
    15th April 08
    Alabama
    Silver plated MOD cantle with white leather formal bag.
    Here is my new bag for my silver plated MOD cantle.
    30th September 08
    Cypress, Texas
    Very nice, Harold!
    19th September 12
    Highland, IN
    That's gorgeous!
    9th August 09
    Seattle
    I love the simple elegance of it Harold. Well done!
    -Martin
    ___________________________________
    "Cuimhnich air na daoine bhon tanaig thu"
    7th July 09
    Melbourne,Victoria Australia
    Very nice Harold, a very fitting colour for the formal occasions. One suggestion, have you tried a collar (for want of a better word) just peeking out from under the cantle. You see them of most formal fur sporrans that have a metal cantle and are usually pinked on the exposed side
    3rd March 10
    43*N 88*W
    Quote Originally Posted by Downunder Kilt View Post
    It looks really sharp, Harold. I'm with Downunder Kilt here, a pinked liner might be the ticket for a little extra pop.
    BTW I really like the silvered bead you used to cinch the tassels, Good call.
    ith:
    Kerrville, Texas
    8 Post(s)
    Very nicely done! Would you wear this with a white sporran belt too, in the military style, or a chain?
    As for the pinked liner behind the cantle, I considered doing something similar on one of the bags I'm building for my MoD cantle, but this seems to be a bit problematic. The snaps that attach to the studs on the inside of the cantle will only allow so much thickness of material before they simply won't stay snapped in place. If I use a leather that's too thick, the snaps want to pop off. And the problem would be compounded when using an additional layer of material (presumably felt) between the leather and the cantle. I'd be curious to know if anyone has successfully done such a liner on this type of cantle, and if so, how they made it work with the snaps.
    And on the same subject of the studs/snaps, it also seems that they placed the studs so close to the inside edge of the cantle that when you stitch the snaps to the leather, some of the stitching is exposed (which is why I considered doing a liner in the first place). The only way I've gotten around it so far is to just avoid stitching the snaps all the way around the hole. Where they would be exposed, I just leave the stitching out. Not exactly an ideal solution, but it should work OK since most of the load-bearing capacity of the sporran body comes from the gussets hanging by the 'knobs' at the hinge point. Anybody else had this problem with the snap stitches?
    3rd March 10
    43*N 88*W
    Yup.
    This is a triple-layer: bag, targe, and liner.
    The leather was skived down for thickness and the snaps are actually stitched between two of the layers.
    This is the reason why the way the MoD had them made works so well. The snaps are actually stitched into a "horseshoe" of leather, which is stitched to the inside top of the bag. The bag actually floats on the studs/snaps.
    sorry this is a little hard to see, being black on black, but you get the idea.
    All of the snap stitches are made on the horseshoe, which makes for a clean face on the bag. I've also found that the bag hangs more smoothly than with a "direct" snap attachment.
    Having done a fair number of re-bags for these MOD sporran cantles, I can say that the spacing on the studs is not super-consistent.
    In one case there was a ~5mm offset from the normal placement, but only on 2 studs. This piece also had the rear plate soldered on at ~8* angle off true vertical (it was tipped clockwise).
    I'm betting that this construction aided in making bags for "good enough for government work" cantles.
    ith:
    Kerrville, Texas
    8 Post(s)
    Yeah, I had to skive the leather around the holes on my first (trial) bag just to make the snaps work. But how do you stitch the snaps between layers of leather? All the snaps I've come across (from the original ones to the new commercially-available ones) have a 'lip' around the edge. I can't see how that would lay flush between layers of leather without cutting off the lip.
    Well, I'll be darned. My MoD sporran was not built that way. As you can see below, the snaps were stitched directly to the front panel, with the stitching showing on the front. The way you describe makes a lot more sense, though! I wonder why mine wasn't made that way. I see no evidence of there ever having been a 'horseshoe' panel installed.
    3rd March 10
    43*N 88*W
    LOL, it took a bit of work, I won't lie.
    It also appears from the picture that your bag is missing the welt in the front seam. I wonder if this bag was not a standard issue bag, but something made to replace a damaged piece.
    I see that the top stitch on the gusset seam appears to be white. Is that from the blanco (so the thread would be a natural colour on the interior of the bag) or is it actually white thread (which I've never seen used on a MoD bag)?
    ith:
