28th December 11, 10:25 PM
Two sgian dubh
These are two blade blanks I cut from a diamond saw blade with my plasma cutter a few months ago, but haven't had time to forge anything out of them.
Didn't get any pics of forging a few weeks back. Instead of going 100% stock removal, I forged a taper into one side of each blade.
Epoxied cherry scales onto both.
The sanded blade and bright, unstained cherry was a bit boring, so I decided to try two different "antiquing" techniques I've read about. The blades were "mustard patina'ed", and the cherry is "ebonized".
The bright blades:
To Ebonize wood with high natural tannin content (redwood, cedar, oak, cherry, walnut), you dissolve steel in vinegar. Since I'd already been sanding my blades to get the grind marks out, I already had a lot of fine steel in my sandpaper, so I just put a dash of vinegar on a small plate and washed the steel filings off the paper. :laughing:
28th December 11, 10:26 PM
Re: Two sgian dubh
Apply the steel/vinegar solution to the sanded cherry handles.
It gets darker
And as it dries out, you add more and it gets darker
And darker
I wasn't sure if I'd ever use these for food prep, so I oiled them with olive oil...and it made them even darker!
28th December 11, 10:27 PM
Re: Two sgian dubh
Mustard patina is easy.
Put mustard on dry blade
The thin spots are where it rusts fastest
Wait and it gets deeper
Fresh water rinse takes a lot of grimy rust off and leaves a nice layer of oxidation.
This is supposed to prevent bad pitting.
28th December 11, 10:28 PM
Re: Two sgian dubh
I'm pretty happy with how these turned out
Re: Two sgian dubh
The larger one is close to 8" long--roughly half handle and half blade...but I'm a tall guy, so I've got room to carry it!
28th December 11, 10:44 PM
Re: Two sgian dubh
Wow, well done. I am one of those that cannot knock a nail in straight,dammit, but I really love the "tricks of the trade" tips, if only fom a; "how do they do that?" point of view. Thank you.
29th December 11, 10:54 AM
Re: Two sgian dubh
Great Job ,I have been thinking of making my own as well , But maybe later.
It is nice to have these pictures to go by ... Great Job
29th December 11, 11:05 AM
Re: Two sgian dubh
If I need any antique armor or weapons forged, I know who to call...
Might I suggest the use of walnut oil as an alternative to the olive oil? Walnut is classed as a drying type of oil as opposed to olive, which is classed as non-drying. Since I started using the walnut in painting, I've found lots of uses for it and you can get it as a food type or a painting medium type.
Best
AA
29th December 11, 12:38 PM
Re: Two sgian dubh
Wowzers... Those are two spectacular blades...
29th December 11, 03:13 PM
Re: Two sgian dubh
I am sooooo impressed! I love seeing hand crafted things and more so when I get to see the process.
By Chas in forum DIY Showroom
Last Post: 25th August 09, 05:04 AM
Last Post: 20th September 06, 02:54 PM
By highlandcelt in forum How to Accessorize your Kilt
Last Post: 11th September 06, 08:37 AM
