Results 1 to 10 of 10
Thread: 2 quick things
    8th February 04
    1 Thread(s)
    2 quick things
    1. When I log in, I get a 'redirect error' message. I can go to the forums section, but it didn't automatically redirect me there
    2. Is there any way to put the breadcrumb trail at the bottom at the bottom AND top of each topic's page? If it's a long page with lots of pictures, I have to scroll all the way back to the top to go to click on the breadcrumb trail.
    8th February 04
    1 Thread(s)
    1 more...
    When you're on a topic page and hit 'forum' in the breadcrumb trail, it takes you to the homepage, NOT the main forum page.
    In case you can't tell, I use the breadcrumb trail often.
    24th September 04
    Rocky,
    To your second point - At the bottom of every page is a "Quick Navigation" drop down menu. This is a new feature to the ver. of vB. If you click on it you can go to any other forum section with a single click. I was hoping that this would be easier than breadcrumbs.
    Just to the right of the quick navigation drop down is a "top" button, This will take you back to the top of the page without scrolling.
    I'll look into your first point. Probably just a re-direct error.
    Forum Owner
    22nd July 08
    Victoria, BC
    I also get a bad URL/redirection error on login.
    24th September 04
    JD, what URL are you being directed to and what do you think it should be?
    Forum Owner
    Breadcrumb trail? Breadcrumb trail? Just what is this bredcrumb trail? I quite accept that URL'S etc are well beyond my technical knowhow, but breadcrumbs are, as far as I know, the things that full under my computer keys when I am posting and eating toast at the same time! Yes and I have told myself dozens of times not to do that!
    24th September 04
    Jock,
    Breadcrumb trails on a forum are a quick way of knowing where you currently are within the forum.
    If you will look up near the top of this page, just under the blue navigation bar and above advertisers you will see a line of text.
    Forum > Forum Issues > Tech Questions > 2 Quick Things
    This is the breadcrumb trail. This trail tells you that you are on the Forum, in the Forum Issues section, the Tech Questions sub-section, in the 2 Quick Questions thread.
    If you click anywhere on the trail you will go back to that part of the forum. It's a trail back along the path from where you are now, hence the name breadcrumb trail.
    Forum Owner
    Thank you Steve. I bet you really wanted to spend time out of your busy schedule to explain basic computer speak!
    May I take this opportunity to thank you and all the staff, including the "backroom wallahs", for all your efforts on our behalf.
    8th February 04
    1 Thread(s)
    In the quick navigation area, the "Forum Home" button takes you to the "Recent Topics" area, not the main forum page with all the sections showing. It looks like every button for "Forum Home" takes you there, not just the breadcrumb trail.
    14th September 05
    Space Coast, FL
    2 Thread(s)
    Rocky, it should take you where expected now.
