Results 1 to 10 of 30
    11th July 12
    Anchorage, Alaska
    How To Improve Your Kilt Pins
    Awhile back I read the following post:
    http://www.xmarksthescot.com/forum/s...ad.php?t=77933
    Dale's comments about kilt pins inspired me to come up with a solution to sagging, 'fabric unfriendly' kilt pins.
    Here are two typical kilt pins.
    And they have the typical pin on the back.
    So I used a rotary tool with a cutting wheel to carefully cut the pins off. The metal was fairly soft, so the cutting was pretty easy
    Then I used a fine file to get rid of the humps and burs.
    I bought some quick-set epoxy and some nickel-plated brass tie-tack posts for this project. Do a web search for tie-tack posts and you should be able to find something suitable.
    I used a grinding wheel on the rotary tool to fit the tie-tack posts to the cross and filed the edges smooth. Then I used the epoxy to glue the posts in place.
    And here is the finished product after letting them sit for the epoxies four-hour set-up time.
    The epoxy seems more than sturdy enough to hold the pins in place. Time will tell. Silver solder might be another option for connecting the posts, but I was concerned about heat discoloring the pins. I'm sure a reputable jeweler could tack the posts on with silver solder, but I don't trust myself to do it.
    This probably isn't something you would want to do to your heirloom sterling-silver kilt pin, but I think it would be safe enough for most pewter kilt pins.
    "Once you can accept the universe as matter expanding into nothing that is something, wearing stripes with plaid comes easy." - Albert Einstein
    18th April 13
    DFW, Texas
    Very nice tutorial and pics. Thanks for taking the time to post this.
    7th February 11
    London, Canada
    Great idea! Thanks for sharing!
    25th September 11
    Missouri
    This is a good idea to replace the standard pin closure on the back of many kilt pins. I use these type posts to make all my kilt pins which run the gamut of stones to metal medallions. They work well and are fairly secure. The issues I have had is the backs pulling off without your knowing it. This has happened most often when I get into my car and my kilt pins gets sandwiched between my thigh and my steering wheel or if my kilt pin unknowingly gets snagged on something. I keep a couple of the backs in my sporran just in case I lose one. This is a nice alternative to the pins usually on the back of the kilt pins.
    This pin has three post type attachments to the back, two at the top and one at the bottom to keep it well centered.
    30th June 10
    San Francisco, CA, USA
    Excellent creative solution
    Great idea. I wish I was such a craftsman.
    I have replaced all my straight pin clamp thingies on my kilt pins with straight pins with a product called "Pin Keepers" They come a dozen to the bag, slip down over the pin, and have an allan screw on the side that you tighten with the supplied allan wrench so you don't have to worry about the clamp part coming off.
    17th April 12
    Franklin, Indiana
    Brilliant! Thanks for the tip!
    15th March 12
    The other advantage to pin keepers is that they don't have the sharp edges associated with the normal pin locks - no scraping on aprons.
    22nd October 04
    Wuppertal, Northrhine-Westfalia, Germany
    I do that with all my kilt pins! Plus it makes it very easy to convert other stuff to kilt pins!
    Shalom
    Hermann
    "Wizards in trousers? Not in my university! It`s sissy. PeopleŽd laugh." said Ridcully.
    Christian Pipe Smoker
    My Youtube Channel
  10. The Following User Says 'Aye' to herminator For This Useful Post:
  11. #10
    22nd March 12
    Charlotte, NC
    This is awesome, but I'm not a fan of those posts. The backs always seem to fall off, defeating the purpose. I used pencil erasers for the pins on my letter jacket; that did the trick.
    Scott McDonald
    "I have inside me blood of kings."
