Just got my first kilt in the post today. I'm concerned about how high the sporran is, for when i try to run it does its *flopp flopp* thing. I'm happy that I'm learning about bits of my history
Sporran is a bit low. Otherwise for casual situations you're doing great.
The grass is greener on the other side of the fence...and it's usually greenest right above the septic tank. Allen
the sporran belt is on the last notch. and it sits that low. where should it actually sit? the chain sits on the area that connects my legs to hips
Originally Posted by TartanCladPB the sporran belt is on the last notch. and it sits that low. where should it actually sit? the chain sits on the area that connects my legs to hips Maybe 2-3 inches higher. Basically most guys wear it right in front of their "junk." You have a lean but average build so if you bring it up a couple of inches it should look perfect. If you have to shorten the chain just go for it. I'd suggest making or buying a strap for everyday and casual wear. It creates less wear on the kilt, and IMO is more comfy and looks better in casual contexts. Overall, you're wearing it well. Kudos. Welcome to the lifelong obsession.
Originally Posted by TartanCladPB the sporran belt is on the last notch. and it sits that low. where should it actually sit? the chain sits on the area that connects my legs to hips Move the 'hooks' at the end of the chains a few links in on either side. Then attach the belt ( in the rear) wherever it is comfortable. Don't be afraid to show some knee either.
the particular clips don't seem to allow me to slide the links out to that it'll adjust that way
Originally Posted by TartanCladPB the particular clips don't seem to allow me to slide the links out to that it'll adjust that way something like this?
how did you do that?
Originally Posted by TartanCladPB how did you do that? "Elbow Grease," son It just takes a bit of effort. When you've got the clips where you want them, you might even consider prying the extra links off with some pliers.
i dont wanna break it xD edit: oops. wasn't gonna use those links anyway. i managed to get em on with the help of a flat head screwdriver
