Results 1 to 6 of 6
Thread: Fly Plaid
    26th September 10
    Fort Collins, Colorado U.S.A.
    Fly Plaid
    Hello, I am heading to the International Tattoo in a couple of weeks and planning on wearing a fly plaid with my PC. My question is this:
    Does the bunched up part go over or under the epaulette?
    7th February 11
    London, Canada
    Under. Wouldn't recommend it though inasmuch as it's likely to snag on stuff.
    26th September 10
    Thanks, I have considered that, but since I will be just sitting and looking pretty...
    7th February 11
    London, Canada
    Don't forget to flip it up before you sit to look good. Otherwise it'll pull itself out along with whatever it's pinned to.
    By the way, the pin on the front of it is only to add weight to balance the long part hanging down behind you. Some guys don't attach it to the jacket at all (if it gets snagged it can rip your jacket) and others use a normal safety pin for a bit of security. If you choose the latter, I would recommend doing so under the epaulette such that if it does rip loose, at least your epaulette will cover it, thus minimizing the visibility of the damage.
    Have fun at your event!
    26th September 10
    Thank you, sir
    While true that fly plaids add a bit of snazz to the outfit, they're somewhat of a pain, because they cause the jacket on that side to droop and/or pull back oddly, and as has been said get snagged on stuff.
