Results 1 to 10 of 25
    13th September 10
    Sacramento, CA
    Question What Collar/Shirt with Sherrifmuir and/or Ruche Cravat?
    I am considering purchasing a Sherrifmuir with 5-button matching waistcoat. I like the look, and can also wear it with tartan 5-button waitscoats I own. I am unsure what shirt/collar works with a Sherrifmuir. Also, one cravat I would like to use with it is a ruche. What collar is a ruche worn with? It looks like it might not work with a wingtip collar usually worn with a PC. Any advice/info would be appreciated!
    A quick search found this, from an earlier X Marks thread, put together by Matt Newsome to show several Sheriffmuir looks:
    In the early years of the 20th century several new Evening Dress jacket styles appeared, first the Prince Charlie Coatee, then the Montrose Doublet and Kenmore Doublet. I have early catalogues which speak of the Prince Charlie Coatee as being a new thing, and document the appearance of the Montrose and Kenmore. I'll have to check and see if I can get an idea of when the Sheriffmuir appeared. (Edit: looked over a few catalogues from c1930 through c1955 and there are no Sheriffmuirs, only Standard Doublets, Prince Charlie Coatees, Montrose "coats", and Kenmore/Morar Doublets.)
    In any case it's a 20th century invention (though perhaps "inspired" by some 19th century jackets) so there's no "tradition" per se about what to wear with it, other than to say that lace jabots were very popular in the first half of the 20th century, and you see lace jabots worn with Prince Charlie Coatees, Montrose Doublets, and Kenmore Doublets. So I would suspect the same with the Sheriffmuir.
    Ruche ties AFAIK are a quite recent invention, appearing at the end of the 20th century, and were therefore not part of the original intended look of any of our Evening Dress styles.
    But that's just history stuff. People wear what they want.
    7th September 14
    Edmonton
    Ruche will work with a wingtip, if Google images are to be taken as advice
    17th January 18
    Berkshire, UK
    Always a wing collar with a rouche, or any cravat worn over the collar and not underneath - in the case of a self-tie rouche the pleating is a little bulky to sit under a turndown collar you see! Most rouches these days are clip on which is a shame as the adjustable band is viewable on the back of the collar. I would urge you to get a proper double-ended one for this reason, and also because (as with a bow tie) they always look that much nicer they are tied as a half-Windsor, fyi.
  5. The Following User Says 'Aye' to Graeme H For This Useful Post:
  6. #5
    13th September 10
    Sacramento, CA
    Thanks for the info.
    OC Richard- The history is interesting. As for the Jabot, as it is generally considered (correct me if I'm wrong here) "white tie" I doubt that I'll ever wear one. I've been to many black tie events in my PC or Argyll; I've never been to a white tie event, nor ever invited to one, and doubt that I ever will be. I will wear it with a ruche cravat, or possibly bow tie, but I don't think it looks good with the bow tie. I think it would look decent with a standard neck tie, but the jacket itself, I believe, looks too formal for that. The photos were helpful. I had found some on line, but they were not clear enough to see the shirt. I blew yours up to 200% and, though blurry, I could learn a bit more. Thanks.
    Taskr- Thanks. That's the conclusion I've come to.
    Graeme H- Thanks as well for the good advice.
  7. #6
    7th September 14
    Edmonton
    With my Sheriffmuir, I wear a stock tie and wing-tip shirt. It took some practice to get it just right; it gets complimented
  8. The Following 2 Users say 'Aye' to Taskr For This Useful Post:
  9. #7
    19th October 09
    South Queensferry, Scotland
    I wear a Sheriffmuir with either a five-button waistcoat, turn-down collar and black bow tie or a six or seven button waistcoat, collarless shirt and highland cravat (like a stock tie but with lace on both ends).
    It's coming yet for a' that,
  10. #8
    13th September 10
    Sacramento, CA
    Quote Originally Posted by MacRobert's Reply View Post
    By "turn-down" collar are you referring to what I would call a wing tip collar? Also, I can't picture the highland cravat, and can't find it on line. You wouldn't have a photo would you? Or, a link to a site where I could see one?
    One of the appealing features of the Sheriffmuire, to me, is that I can wear it with my 5 and 6 button tartan waistcoats, as you do.
    Thanks!
  11. #9
    16th September 10
    47 Post(s)
    As I have mentioned elsewhere, in my current life I have no need for formal attire. If the occasion should arise, and any here
    spot me in a ruche tie, please contact the nearest veterinarian and have me put down, as I will clearly have passed my sell-by
    date. I have never seen one tied in a way that did not appear sloppy and inappropriate. Perhaps it can be done; I have never
    encountered such.
    The above should be considered personal opinion only, not advice. Any photo of me will clearly demonstrate my lack of sartorial
    elegance.
  12. #10
    30th December 16
    Edinburgh
    I love my Sherrifmuir doublet. Unfortunately, I cannot find a picture of me in it at present and I cannot throw it on as my shoulder has been immobilised by a rather nasty car and consequent operation. However, I tend to wear it with a jabot sans cuffs or (rarely) with a bow tie. On both occasions with a wingtip collar. The jabot hides the wingtips. I picked it up from a historical costume shop for about £15.
    Whilst the jabot is more white tie, I have worn it at a black tie Brewers and Distillers Guild dinner. Distillers tend not to be shy after a few drams but there were no negative comments.
    Please note that this is just me though and, as mentioned previously, there is no set-in-stone rules due to the relative youthfulness of this doublet. Try on a couple of tie types and see what is aesthetically pleasing to you.
