19th November 12, 07:22 PM
Almost finished xkilt...what do you think of the length?
Greetings again,
I decided I had turned a corner in the construction of my xkilt and it was time to start a new thread.
As you can see I have made it to the point in Alan's instructions when he says, you can belt in on and impress your friends. Just need to complete the aprons and waistband. I think I understand how the inner pleats and everything goes together. The one thing I discovered when I put it on was that it appears a little long. It's a little hard to tell because I think the extra fabric on the inner apron is hanging a little, but what do you think of the length? For what it's worth, when kneeling it just reaches the floor.
19th November 12, 07:48 PM
It does seem a bit long to my eyes. I would go up on it nearly an inch, give or take. I personally like mine between the middle and the bottom of the knees, and it looks in the second picture like it is sitting a little ways below the knees.
Otherwise, looking good!
19th November 12, 09:22 PM
Yeah, that's kinda what I was thinking too. I was thinking about just turning over the top and sewing it over ... doing away with the waist strip that normally would hide the raw edge. Any thoughts?
Also anyone able to take a picture of the reverse pleat and under apron? That bit of the instruction just isn't making sense to me. I think I have it right, but just need some confirmation.
19th November 12, 09:35 PM
One of the great things about the X Kilt...and really ANY "contemporary" kilt, is that there aren't a lot of rules. so I'd say, do YOU think that YOU want to shorten it? If so, then go ahead.
Personally...just my opinion, I think it looks just fine at that length.
20th November 12, 08:58 AM
Oh, and sorry about the socks. (At least they werern't black) I had my wife take the picture so I could see the length and wasn't thinking about posting them.
20th November 12, 08:59 AM
Hope this helps, only one I have.
Camo XKilt reverse pleat and under apron
20th November 12, 09:10 AM
Yes, that does, thank you. That I think looks like what I have ...once I get it pressed into place. (I think that is one of the elements that is hanging below the apron in my photos and may be giving the impression of length Can I ask how large is the inner pleat in between the apron pleat and pleat # 1? (In your photo it is the pleat that is standing almost vertical from the table at the hem)
20th November 12, 09:45 AM
I don't have the kilt itself handy to measure, so I'll try it with words.
You can just barely see the chalk line for pleat #1 (on the right side of photo). From that chalk line to the edge of the under apron is the reverse pleat. Align the left edge of the underapron with the chalk line and you have formed the reverse pleat. It is whatever width you make it. . . I think Alan gave some numbers earlier based on your apron width.
Yes, that edge will tend to hang down if you have tapered the edge of your apron. But you don't need to taper your under apron, just the outer apron. And there are tricks to keep the pleat from hanging below the hem of outer apron -- easiest being to just increase the amount of hem at the fold of the pleat, which is exactly how it's done on a traditional kilt!
20th November 12, 10:09 AM
Thanks Sydnie. What confused me, I guess was that the inner apron pleat does not extend across the entire apron (at either the top or the bottom). But it doesn't seem that yours does either.
Does this mean that the inner fold of Pleat # 1 is tapered?
20th November 12, 10:22 AM
If you taper the edges of your top apron (A-shaped with waist edge narrower than hem edge), then make straight folds for the first pleat, rules of geometry mean that the hem edge of that first pleat will not be parallel to the hem of the top apron. It will droop and show. There are ways around this (Pleater likes to just "pull the top edge up a bit" as she sews the waistband on), but Barb T shows and explains the traditional fix in this wonderful thread. The Wizard chimes in at post #8 with comments about accomplishing this in a non-trad fabric.
And no, the inner apron pleat is not the full width of the apron, no worries there!
