17th January 11, 11:27 AM
Bulge at underapron strap
Hi All
I just made a tank for a woman 35.5 "W 44" H with a 1.5" rise.
The overapron lines up perfect but there is a bit of a "Pooch" where the underapron strap comes through the hole on the front apron.
The straps are at the last hole and the over apron fits nice and snug (except for the pooch) but the underapron is a little loose.
This is my first kilt with a "womans measurements" I am used to guy kilts with no shaping.I did all measurements by the book except the shorter rise. did that goof something up? not having a full 2" rise?
So how can I fix this? do I move the straps a little back towards the center of the apron? will the kilt "settle" after it has been worn a bit.
Thanks for any advice
17th January 11, 06:19 PM
 Originally Posted by Tartan Tess
Hi All
Shouldn't have anything to do with the shaping. But, can you clarify? Is the "pooch" in the top layer (the apron) or in the underapron? If it's in top top layer, move the apron edge buckles toward the back of the kilt. The "pooch" comes from the fact that you can buckle the underapron tighter than you can the apron. Or else just have her not buckle the underapron so tightly.
If the "pooch" is in the underapron, move the underapron strap toward the center of the underapron.
You wouldn't even have noticed this except that the straps and buckles are put on where they are in the very last holes. If they were over a bit, and were not in the last holes, she would simply buckle them both until things were smooth.
17th January 11, 08:51 PM
TT, this sounds like what you're describing.
18th January 11, 03:54 AM
The "pooch" is in the overapron from where the strap comes through, on the left hip towards the center of the over apron. The bulge is about 1 1/4 " of tartan.
While buckled on the last hole of the strap, the underapron is looser, has some movement up and down if you wiggle it.
Should I move all the buckles toward the back a bit? Front and underapron buckles?And if I want the strap holes to be buckled on approx the center hole punched should I move the buckles about 1 1/2" which is the distance from the last hole to the middle hole punched in the strap. Would just an inch would work?
Thank all!
18th January 11, 11:44 AM
Thank all!
Put the kilt on her, but don't put the underapron strap through the hole. Just wrap the strap around her body toward the back. Pull the apron across the front of her body as snug as she wants to wear it, and see where the fringe edge falls with respect to the buckles. You'll see immediately if the buckles need moving. And then peek inside at the underapron strap and see where it's stitched relative to the buttonhole. You'll be able to see whether you need to move the strap toward the center of the underapron or not.
18th January 11, 11:47 AM
Hi Tess,
Is the underapron strap on the outside of the underapron? If not, then move the unerapron strap back a little (1/2"?).
Happy kilting,
18th January 11, 12:03 PM
Yes, the underapron strap is stitched to the outside of the underapron. And
Barb,I will try it on her and look for the clues that you suggest.
I thank you all for your help.
I was worried I really goofed on something in the shaping. I was getting discouraged since the last kilt (for a man) came out perfect.
Now I keep hearing Elsie in the background telling me that she was an "Apprentice" for 5 years before she was considered a kiltmaker.That's why I keep going to kilt camps.....
....and I love this site because between them, you can cry for help and people come to the rescue!
18th January 11, 12:31 PM
 Originally Posted by ChattanCat
Hi Tess,
Happy kilting,
The underapron strap actually has to be on the outside (the tartan side) of the underapron (not on the lining side), otherwise the edge of the underapron gets in the way when you try to put the strap through the hole.
18th January 11, 12:32 PM
It's possible that the waist is simply too big for the hips, but you'll find that out quickly when you wrap it around her.
18th January 11, 01:52 PM
Sorry, I couldn't resist as I know you have made many kilts.
Wow, I only have a year and a half to go! WOOT!
By raibeart_dubh in forum DIY Showroom
Last Post: 8th June 09, 07:05 AM
By BearMinister in forum Kilt Advice
Last Post: 14th March 09, 11:48 PM
By ninjaschopheads in forum General Kilt Talk
Last Post: 6th March 09, 07:43 PM
By gu3 in forum How to Accessorize your Kilt
Last Post: 18th August 08, 06:07 PM
Last Post: 26th April 06, 09:51 AM
