21st April 12, 12:22 PM
Dyeing Juzo Compression socks with Dylon dye
The socks were white Juzo 5760 knee high compression socks - 85% cotton, 5% nylon, 8% lycra and 2% X-static. $17/pr.
These cushion soled compression socks are what works for me. They only come in black and white...
All socks were laundered before and after dyeing before comparing colors. After all socks were dyed and washed, they were rewashed and dried (half dryer/ half hang) two more times.
The Dye - Dylon Permanent Fabric Dye ( one envelope for 1/2 lb.fabric ) Used in warm water with salt. Per directions - unless otherwise stated.
The Kilts - top to bottom in the picture.
SWK - HW wool, Irish Saffron "Shadow Tartan".
Heratage of Scotland - PV, Heratage of Ireland.
USA - Economy (2011?), HW wool, Black Watch.
USA - Casual, PV, Spirit of Scotland.
Purple - Intense Violet color - 8.3 oz fabric wt - 1 pr socks + t-shirt. Results - two shades lighter than envelope and Sprit of Scotland. Probably due to a bit overweight and 85% cotton socks.
Brown - first run - Terra Cotta color - 6.9 oz fabric wt - 2 pr socks. Results - Much oranger than the Irish Saffron. Might have worked with the brighter Saffrons I have seen
- second run (over dye) - Dark Brown color. Results light and still quite orange. Probably due to most of the dye sites already in use.
Note - these were much closer to the saffron kilt until the final two washings, half drying in the dryer on low heat. First dye had all the good dye sites - the dark brown was mostly out of luck.
Greens - first run - Amazon Green color - 6.9 oz fabric - 2 pr socks. Results - Bright yellow shifted Green.
- second run (over dye) - Dark Green color - the light pair were pulled and rinsed at 10 minutes into dyeing the dark went the full dye time. Results the light is a good match to the white/green stripe on the Heratage of Ireland. The darker green is lighter than the other greens on the "S of I" but is a great match to the Black watch.
Note - Checked the greens against my SK Comfy Black Watches - the kilts use a darker green.
5 more Pair of whites on order ($80). May order a dark gold color Dylon dye for the saffron and S of I.
slàinte mhath, Chuck
I just noticed your post. It's pretty interesting for me, while I was doing some experiments with wool/nylon/synthetic/??? mixture hose. The thing is that nylon takes dye the same way as wool. So you could gain some more darker shade if you use wool dye to cover those 5% of nylon. But the question is if it's worth. Don't know how lycra is taking dye (and what type). Just in case you need some experimenting ideas. Wool/nylon is taking also some "natural" dyes; like tea, coffee, food colorants, plants... you can even try some hair dyes (after all wool is some sort of hair)
Such experiments are very interesting, you never know when you'll need some suggestions. We really don't need to repeat errors that someone already did, right?
By the way, I like the results; all socks look great and make a nice accent to kilt.
Regards!
The Dylon permanent dosent color the lycra/spandex at all.
This is a picture with the terra cotta/brown socks on my feet.
Dylon makes dyes that will work "on all synthetics" but they require hot processing that the Lycra would not survive.
Juzo rounds 2 and 3
Round 2
This installment in the quest to match the saffron kilt includes dyeing a pair of Juzos and a pair of Sigvaris 182c cushioned cotton support (15-20mmHg) socks with Dylon Jeans Blue The Sigs ( cross ways at the bottom ) are 68% cotton, 25% nylon and 7% spandex.
Happy it didn't turn out as well as these cost about twice what the Juzos do! I stuck a bowl in both blues so you can see the none cotton component that shows when wearing on both. Its a bit larger than my calves. The white isn't very obvious in wearing from a short distance - see pictures I posted with the leather British Tan R Kilt and purple Juzo socks.
Round 3
This is another crack at saffron and is two pair Juzos and two bags of Dylon Permanent Fabric Dye - one Goldfish Orange the other Dark Brown mixed in the same dye batch - normal dyeing insructions. Pictured at left end.
This was also sock wash day. May continue doing this as the camera did'nt try to diddle with the colors - whee - one shot got it!
Picture is daylight via my skylight. Colors look accurate.
This saffron is keeping me safely crazy. My eyes say its an orange shifted brown. My color wheel says it is a yellow shifted brown. Hmm, Arrg. WARNING - this is SWKs current saffron HW wool, I have seen yellow to orange to brown and everything in between called saffron!
Errr scuse me bein a non-understanding Scotland dweller, but what's with all the matching of socks with kilts? I have bottle green, rustic green, purple, burgundy, lovat blue, black and navy blue and wear all (not at the same time) with both my MacLaren ancient and weathered kilts. I tried dying a pair of white hose with tea but they now just look flesh coloured so only wear them at home.
Chris.
Chris, it's a bizarre North American thing derived from folks who don't understand that your tartan is your tartan is your tartan and matches everything and anything because it's your tartan that's your tartan. I mean, you don't try to match your moustache colour to your hose, do you?
I have to wear the compression hose/socks and they only come in black or white - black has gotten boring and white gets dirty too fast - I live in the desert. This Dylon dye fades very little and is one of the few permanant dyes that can be used with just warm water. Rit and even Dylon washing machine dyes are non permanent.
Dylon brand actually started in the UK and is still based there.
Bill, my mousy grey mustache will probably match Chris's faded tea stains?
http://www.youtube.com/watch?v=CPL503kUo3Y
13th May 12, 06:07 PM
Great response!
