Results 1 to 10 of 14
WalesLax Help Removing an Invisible... 18th May 20, 01:55 PM
figheadair Could we see a picture please. 18th May 20, 02:45 PM
Father Bill Including a closeup - as... 18th May 20, 03:59 PM
The Wizard of BC And please include a close up... 18th May 20, 09:32 PM
WalesLax http://www.xmarksthescot.com/f... 19th May 20, 12:58 PM
    7th June 14
    Long Island, NY - via Chicago, IL, USA
    Help Removing an Invisible Stitched Hem
    I recently bought a kilt that had been hemmed using an invisible stitched that set the length from 24" down to around 22". I was told that the selvage edge still in original condition and was never cut when they altered Kilt to make shorter, it was simply folded & stitched.
    Under normal circumstances, I would either be reaching out to one of our sponsors or the local tailor (who does the kilts for a number of the bands in my area) about "fixing" this issue, but given the current climate we are in, I'm wondering if this is something that I might be able to fix/undo fairly easily myself.
    So, for someone with virtually no seamstress experience under my belt, I am curious if people would suggest that I could do this myself, or advise that I just hold off and let a professional do it.
    I would also like advice on, once I remove the stitches holding up the hem, do I just steam out the crease?
    Thank you all in advance for your help, and understanding my level (or lack thereof) of kilt modification.
    Rob
    2nd January 10
    Lethendy, Perthshire
    16 Post(s)
    7th February 11
    London, Canada
    Including a closeup - as close as you can get it, please.
    And please include a close up of each apron facing so we can see how the fabric is folded.
    Please include the small turned up areas at the other side of the apron so we can see how that was done too.
    I wear the kilt because:
    Swish + Swagger = Swoon.
    7th June 14
    23rd March 19
    Seattle
    Nova Scotia?
  7. The Following User Says 'Aye' to Bad Monkey For This Useful Post:
