8th October 11, 04:15 AM
Kilt belt pattern
Some 15 years ago I made a kilt belt without a pattern at all. Problem is I've expanded and the size no longer fits and I made it so that it doesn't adjust. So, does some one have a style that adjusts but will not hinder a hanging sporran. Trying to lose weight would be the best thing, but realistically that isn't going to happen!
8th October 11, 07:21 AM
Re: Kilt belt pattern
These pictures should give you enough to go on. The only curve ball with this design is that you need a leather that's strong without being overly thick; try English bridle leather.
Belt design by Ferguson Britt, and buckle by Tyger Forge.
8th October 11, 07:46 AM
All my kilt belts are expandable. The buckle end doubles back on itself similar to the one pictured above but the "extra" is much longer and there are no studs as it is held in place with velcro. These allow an expansion of many many inches which in my case is just as well.
In this example you can see what I mean but I personally don't like this belt it is an example only.
http://www.thescotlandkiltcompany.co...ic-buckle.html
8th October 11, 10:08 AM
Thanks on the two suggestions, I'm thinking of combining the two. My first kilt belt was static on the buckle end, and the right adjusted by narrowing down past the latch a ways, which narrow part had holes punched, but the clasp for this was on the inside of the belt and in time would wear a hole in the waist band. I didn't like this. When I made my own wasn't expanding (was also positive I wouldn't be either ).
8th October 11, 11:42 AM
Why not? Lots of guys on Xmarks are doing it on the "Fitness Challenge" thread.
Hugh
8th October 11, 12:08 PM
 Originally Posted by biblemonkey
Why not?
Seriously.
8th October 11, 07:10 PM
Appreciate the challenge offer. I've become very strict diabetic who MUST have insulin but my system doesn't process it very well. Since going on insulin five years ago I've gained about 60 lbs. Been eating a 500-1200 calories a day for two years, and I gained 20 lbs. Biggest problem is I have two back injuries that prevent exercising, I can't even do walks anymore. My back muscles will seize up just brushing my teeth or getting a glass of water. But I must say go you!
8th October 11, 08:35 PM
Wow... I think that's the best answer humanly possible, good sir.
...let us know if you need any further help on that belt.
8th October 11, 11:23 PM
Slainte Mhath, Ryan Ross, good cheer!
9th October 11, 07:21 AM
Likewise.
By NorCalPiper in forum DIY Showroom
Last Post: 20th June 10, 02:17 PM
By runewolf in forum How to Accessorize your Kilt
Last Post: 5th January 09, 04:38 PM
Last Post: 7th July 08, 08:49 PM
By Rogerson785 in forum How to Accessorize your Kilt
Last Post: 23rd January 08, 07:16 PM
