24th March 14, 02:20 PM
Kilt pin project questions
I am putting together a mini-flask kilt pin. The first thing that springs to mind is how heavy is too heavy for a kilt pin? This set-up weighs a couple of ounces when filled with an emergency shot of Laphroaig.
And I still heven't decided the best method for attaching it to the kilt apron. Anybody have any ideas?
24th March 14, 03:48 PM
My thoughts:
First, if those are wet stains on the leather, from a leaky flask cap, I'd not want the liquid staining the kilt.
Second, 2 ounces when full sounds a bit light, but I'd bet the flask would beat against your thigh the way tassels drum on a sporran, when you walk.
Third, I'd use more than one pin to carry the load, and would recommend they be placed horizontally, to maximize the number of holes in the fabric that need to support the weight (rather than a single vertical pin from which all the stress is hung on the top hole.) There are those here who like magnets, but I don't think magnets would support something as heavy as I imagine that would be, and securing magnets to the leather could be a challenge.
Finally, it just appears too "bulky" to make a good pin, and I suspect it would get bumped by just about everything... other people as you brush by them... the table as you take a seat... the steering wheel as you get in/out of your car... all those bumps or snags would put unwanted stress on the pin holes, in the apron.
I'm not convinced it would make a good pin. Sorry.
KEN CORMACK
Clan Buchanan
U.S. Coast Guard, Retired
Cuyahoga Falls, Ohio, USA
24th March 14, 04:24 PM
I would probably be better in the sporran or worn around the neck if you're dressed very casually.
Natan Easbaig Mac Dhòmhnaill, FSA Scot
The Following User Says 'Aye' to Nathan For This Useful Post:
24th March 14, 04:36 PM
They're not.
Weighed it on three different scales, the heaviest it weighed was a little over two ounces.
No need to be sorry. I asked for your opinion, I'm likely still going to try it.
24th March 14, 11:45 PM
Seems like it would be a bit heavy for a kilt pin , however , if you are comfortable with the weight and don't think it will damage the fabric ... then go for it .
On a side note , a single shot of Laphroaig is not enough for an emergency !
Mike Montgomery
Clan Montgomery Society , International
The Following User Says 'Aye' to MacGumerait For This Useful Post:
25th March 14, 08:11 AM
I might attach two small leather straps to the flask, add a pin on each to give it a mini sporran look. That would give you two attachment points that are horizontal. If the swing bothered you you could always add a third pin behind the flask. Just my thoughts...
Life Is Short - Enjoy The Swing, Sway and Sashay - Go Kilted
25th March 14, 09:30 AM
A single shot of Laphroaig is an emergency !
St. Andrew's Society of Toronto
The Following User Says 'Aye' to JohntheBiker For This Useful Post:
