Results 1 to 6 of 6
    24th August 08
    Washington State, USA
    knot and loop closure
    I'm working on a D.I.Y. sporran, and I'm intending on using a knot and loop closure. Admittedly, I'm inspired by the Ferguson Britt style. So, I was wondering if there is anyone out there who has photos of the opening on a Ferguson Britt sporran such as the Duin Uasal style? I'm curious how the cantle is constructed, as I'd like to attempt something along those lines.
    Anyone have any photos that might help, or any advice?
    Thanks,
    Brad
    "Far an taine ‘n abhainn, ‘s ann as mò a fuaim."
    Where the stream is shallowest, it is noisiest.
    26th March 08
    Atlanta, GA
    Re: knot and loop closure
    Do these help? The knot Lamar uses is just a single overhand knot, and the cantles are made from successive layers of leather.
    Kerrville, Texas
    8 Post(s)
    My wife made me a sporran that's similar to the Ferguson Britt ones shown above (though not nearly as detailed or well-made, as she's a saddle-maker, not a sporran-maker). So I can't speak for how he does his specifically, but this seems to work for mine:
    From the rear of the sporran, a round-braided leather toggle comes over the top, and is finished with a Turk's-head knot. The front of the sporran has two holes in the leather just below the cantle. A single piece of flat 3-part braided leather comes through these holes so that it forms a loop at the top. Note: both ends of the flat-braided part go through both holes. The intent is that you pull the loop up and put the Turk's-head knot through it, then grab the 'tails' of the flat-braid and pull them down. It tightens the loop over the Turk's-head knot and pulls it snugly over the cantle, keeping it closed.
    So what you're seeing in my picture below is the Turk's-head knot with the flat-braided loop pulled snugly over it, and the tails of the flat-braid hanging down (as they emerge from the lower hole in the front of the sporran, which is hidden by the braids).
    I don't know if that made sense or not, but there ya go.
    And I don't know how Ferguson Britt makes his cantles, but mine were just made from flat-braided leather, stitched down over a couple of other pieces of leather for stiffness. In retrospect, if I were to do another one, I'd embed something even stiffer in there. My sporran tends to gap open a little at the sides when it's stuffed full, because the cantle isn't stiff enough. It was a learning experience, though. I'm sure you'll end up making several of them before you 'fine tune' how you want yours to perform.
    20th May 07
    Madison, WI
    Here are some pics of my FB sporran. I hope this helps...
    [B][U]Jay[/U][/B]
    [B]Clan Rose[/B]-[SIZE="2"][B][COLOR="DarkOrange"]Constant and True[/COLOR][/B][/SIZE]
    [SIZE="1"][I]"I cut a stout blackthorn to banish ghosts and goblins; In a brand new pair of brogues to ramble o'er the bogs and frighten all the dogs " - D. K. Gavan[/I][/SIZE]
    24th August 08
    Awesome pics... That helps alot!
    24th August 08
    Alright.... So I finished my first attempt at a somewhat presentable sporran. I made it out of fairly heavy leather since that's what I had lying around. I used photos of some different Ferguson Britt sporrans as my primary inspiration, and the cantle shape was influenced by Artificer's work. The straps are latigo, which is probably a bit thick for their intended use, but everything works, so I'm calling this a success, even though it's not what I'm looking for in a final product exactly. I have a side of buffalo hide in the garage begging to become a few sporrans, and this project has been a good learning experience. I'd be interested in everyone's feedback/advice/whatever. What do you think??
    Here's a picture (forgive the lighting) of the sporran:
  1. Unravelling Belt Loop
    By MacIsaac in forum Care & Maintenance
    Last Post: 25th June 11, 02:26 PM
  2. Sometimes you just get thrown for a loop..
    By NorCalPiper in forum Miscellaneous Forum
    Last Post: 8th February 11, 09:39 AM
  3. belt loop usage?
    By oxter in forum Kilt Advice
    Last Post: 30th April 09, 09:59 AM
  4. Fly plaid loop
    By gilmore in forum Kilt Advice
    Last Post: 21st April 07, 12:33 AM
  5. Out of the loop....!
    By Blu (Ontario) in forum General Kilt Talk
    Last Post: 9th May 04, 12:53 PM
