18th July 11, 11:30 PM
19th July 11, 03:37 AM
Hold on. You don't cut out the excess in a box pleat.
If you are using the supplement by Matt and Barb see
the *note box on page 30
19th July 11, 05:06 AM
A Military Box-Pleat is not the same type of Box-Pleat that Matt makes. It's really a knife-pleat with the pleat edge turned back on itself. Different animal....
19th July 11, 01:39 PM
Yeah...umm...
Which type of kilt are we talking about here? I can't tell for sure, but from the look of the picture that looks more like a box pleat kilt rather than a military box pleat. The pleats appear to be very wide for a knife-pleated or military box pleated kilt.
If you're using Barb's instructions, it would also lead me to believe you're talking about box pleated kilts rather than military box pleats...since Barb (to my knowledge) does not make those and I know she hasn't made a "how to" guide on them.
19th July 11, 01:52 PM
It is a Military Box pleat ( the pleats are approx 1" wide), NOT a ( Matt style) Box pleat.
(I'm wondering how much seam allowance to leave, when cutting out the material in the fell)
19th July 11, 02:34 PM
Looks atypical due to the fact that most military box pleats are to the similar stripe in all pleats.. hence the questions...
I like the alternating stripes quite a bit
20th July 11, 02:59 AM
It depends - like most things which are a matter of experience.
If the fabric is firmly woven then you can cut out more than if it is loose and likely to fray.
Maybe if you trim to 1 inch from the fold - as the pleats are 1 inch wide, so the number of layers are minimised but there is a smooth surface for pressing, no lumps or dips to make an uneven surface.
I have to cut out box pleats - if made in a firm fabric such as cotton, as the tapering sides of each panel are longer than the centre. It is impossible to make the fell lie flat without removing the fabric under vertical tension. Those with a need for less tapering will not have the problem.
Anne the Pleater :ootd:
20th July 11, 03:37 AM
I haven't made a military box pleat but the interfacing will take the load when tightening the straps. Not sure why you would need more than 1/2".
BTW, the kilt look great!
20th July 11, 10:03 AM
20th July 11, 08:11 PM
well, without further experienced advice, I've gone ahead
I've left 2" seam allowance , along the sides, curving down to 1" above the bottom of the fell. The pleat reveal, in the fell, is about 1" wide, so, on the inside, each side of the pleat, in the fell, overlaps about 1" ( or 2 pleats).
I'll see how it works out - better too much than not enough ( i hope)
By Calico in forum Kilt Advice
Last Post: 12th March 11, 05:04 AM
By S.G. in forum General Kilt Talk
By David White in forum Show us your pics
Last Post: 11th July 08, 05:35 AM
Last Post: 20th August 07, 12:42 PM
By auld argonian in forum General Kilt Talk
Last Post: 31st December 05, 04:04 PM
