Results 1 to 7 of 7
    5th April 13
    Howell, Michigan
    Need Advice: Leather for Hybrid Sporran - hand sewing, etc.
    Hi,
    I've made a couple of sporrans with non-traditional materials. The latest one is "okay", but I want to improve on it. It's tweed and duck canvas (pics below). Although the duck canvas worked pretty well for the gusset, I think it would look, feel, and function better if I use leather. The panels can still be made from layers of duck canvas and tweed.
    I've never worked with leather. I understand a chisel tipped needle is used for machine sewing leather, but I prefer to sew by hand. Is the leather typically used for the gusset something I can hand sew? Are there chisel shaped needles for hand sewing leather or is an awl and blunt round-nose needle (like a x-stitch needle?) typically used?
    Thanks
    3rd March 10
    43*N 88*W
    When hand sewing leather you have two primary choices, a sewing awl tool that makes a lock stitch,
    OR
    the much stronger two-needle saddle stitch. This can be accomplished with either harness needles or a triangular profile Glover's Needle.
    The benefit of the (very sharp) glover's needle is that you don't need to pre-punch your holes, but you WILL end up stabbing yourself eventually.
    Glover's Needles
    ith:
    5th April 13
    Howell, Michigan
    Thanks!
    The two-needle saddle stitch appears to have a "cleaner" look to it.
    I think I may have stumbled into another hobby I don't have time for :-)
    14th July 12
    St. Paul, Minnesota
    BTDT—Got the puncture marks to prove it.
    If you do much of this, you'll also eventually want a stitching pony. A carpenter's vice also works well. It holds your work in place while you stitch.
    If you are using thin leather in addition to the cloth, you can sew it on a sturdy machine, but you will need leather needles. They cut the holes in the leather rather than trying to punch through like a cloth needle. If they're the appropriate size, this lets the thread feed through much easier.
    Good luck.
    5th April 13
    Howell, Michigan
    I found a video of someone using an old Singer machine with chisel tipped needles. I suspect a "modern" sewing machine, even my wife's 35 year old Kenmore, might not be up to the task for leather thick enough for the gusset. I like the idea of hand sewing them anyway.
    A stitching pony sounds very useful. Maybe I'll avoid sticking myself as much as I already do with a simple needle and upholstery thread. Glover's needles look pretty wicked.
    I also watched a video explaining saddle stitching. Do you cut a stitching groove? With the relatively thin leather for a gusset, it looks like it would remove too much material.
    Thanks again for the advice.
    19th July 11
    London
    Cutting a groove for stitching is generally only done in places where its likely the stitches will take a bit of a beating. So it would be unnecessary inside a sporran or bag gusset. If you're worried about the stitches you can make a crease in the leather which will tighten the fibres and sew along that but more then likely this will be over kill.
    5th April 13
    Howell, Michigan
    Quote Originally Posted by Emmet View Post
    That's logical. Thanks!
