Results 1 to 7 of 7
Thread: No stripe kilt
    13th May 13
    Idaho
    No stripe kilt
    My wife is going to make me my first homemade kilt with gray material
    What is the best measurment for the pleats?
    I saw where one person was making a cargo kilt and was using a 2 inch pleat. Is this a standard?
    Any help is greatly appreciated.
    Starhunter
    7th February 11
    London, Canada
    The kiltmakers will surely chime in shortly, but meanwhile, welcome to the "Great Rabble!"
    19th May 08
    Oceanside CA
    What is she using for guidance? There are instructions for an easy X-Kilt available free for download elsewhere on the forum (I'll search and post a link if nobody beats me to it).
    Edit: Here you go: XKILT MANUAL DOWNLOAD LINK
    If she's a more accomplished seamstress, invest in Barb T's book The Art of Kiltmaking (again, a search will reveal link to her website for direct purchase -- ignore those Amazon resellers!).
    Edit: Art of Kiltmaking link
    Pleat measurement is also a function of your waist/hip size and the amount of material you have/want to use. More info will help us narrow it down for you (so to speak).
    Welcome and keep posting!
    The width of the reveal of your pleats will depend on what 'look' you are going for.
    The wider the pleats the more rugged the kilt will look.
    The narrower the pleats the more refined the kilt will look.
    If you are going to wear your kilt mowing the lawn or hiking the bush you will probably wider pleats. I use 1.5 inch wide pleats in my Cargo Model kilts.
    A traditional kilt will have pleats somewhere around 5/8" to 1 1/8" wide. This gives what most people are used to seeing on a traditional, Tartan kilt.
    If you are making a kilt from a solid color fabric the width of the pleats is not as important as the depth. A Polyester/Cotton blend fabric is a bit stiffer than kilt wool and will need deeper pleats.
    How deep to make your pleats you ask? Well, again, it depends on the style and look you are after and how much swish you want your kilt to have.
    I wear the kilt because:
    Swish + Swagger = Swoon.
    13th May 13
    Idaho
    Thank you for the info.
    15th August 12
    Tennessee, USA
    The Official [BREN]
    13th May 13
    Idaho
    Thank you. That was very informative for her and somewhat confusing for me. Luckily she.is.the one in charge of the project, though I will.be doimg most of the cutting under her guidance.
