Results 1 to 6 of 6
    19th May 11
    Albuquerque, New Mexico, USA
    Putting Posts on about anything as kiltpin
    You can turn just about anything into a kilt pin by attaching posts to the back.
    I highly prefer post and clasp over the "safety pin" attachments as the pin lays totally flat to the fabric, is a lot less snag prone, is easyier to position and does a lot less damage to the fabric than the other attachments.
    I like it so much that I have ground the "safety pins" off of kilt pins and put in posts.
    I've had real good luck drilling holes part way though the back of things and JB Welding (a metal epoxy) the posts (with the heads snipped off)in the holes. I even have a rather heavy metal 4 inch chrome plated brass cross that hasn't come apart in over a year. The tiny drill bits are hard to find in these sizes, I got a PC (printed circuit) board drill bit set on Amazon.
    I clip the post tops off for two reasons - First Chrome to chrome dosent stick well. And the heads are too large for many of my pins. Epoxying is a lot cleaner with a hole - You just poke a drop of the (mixed) epoxy in the holes and push the posts in with needle nosed pliers and let it set to cure.
    These posts with heads are really ment to be soldered on and the heat will damage most finishes etc.
    TurboKittie is offline Oops, it seems this member needs to update their email address
    3rd May 11
    St Louis, Missouri
    Re: Posts on about anything as kiltpin
    I have far too much fun turning things into kilt pins and posted photos of most of what I've done so far here
    19th May 11
    Quote Originally Posted by TurboKittie View Post
    OH MAN, you made some neat stuff. Kicking my semi fertile mind into gear.
    3rd May 11
    St Louis, Missouri
    Why thanks. I especially like the working compass. One of the round octopus pins is also a magnetic locket, which is interesting.
    Some thing were intended as pendants, but a few snips and a little grinding, and you can't even tell. Some of the heavier pieces need three of the tack style pins for balance, and we usually put a small square of cardboard in the back to help hold them in place when worn.
    3rd May 11
    St Louis, Missouri
    I usually use epoxy, and sand both the pin back and where I'll be putting the epoxy, wearing small scratches in there to give it someplace to grab onto.
    19th May 11
    TK I did the grind thing but chrome tends to chip out where it is visible. The investment in the tiny drill bits is well worth it and seemed pretty cheap on Amazon. Post in hole never comes loose. And is quick to make.
  1. First X Marks Kiltpin Auction
    By highlandtide in forum How to Accessorize your Kilt
    Last Post: 2nd April 06, 07:56 AM
  2. Grouse Claw kiltpin
    By Robin in forum How to Accessorize your Kilt
    Last Post: 9th March 06, 06:36 PM
  3. My X Marks Kiltpin Came Today.
    By Bob C in forum How to Accessorize your Kilt
    Last Post: 4th October 05, 05:05 PM
  4. Kiltpin on my AmeriKilts
    Last Post: 1st September 05, 09:22 PM
  5. The kiltpin
    By Kilts_Knave in forum How to Accessorize your Kilt
    Last Post: 4th July 05, 11:47 PM
