Gearing up to start my first DIY kilt (Canadian Navy PV, 4 metres double-wide) armed with a thorough reading and handy copy of Barb T.'s wonderful book.
I am a portly man. My middle looks from the side much like a double-bent stove pipe. Waist (cinched to kilt-holding tension) is 46", hips, loose, 48". That leaves very little wiggle room in working out a split which yields an apron taper from waist to hips while still allowing some shaping.
My best split try so far has been to increase the hip measurement to 49", resulting in the following calculation:
Waist 46" Aprons 23" Pleats 23"
Hips 49" Aprons 24" Pleats 25"
This gives very little shaping and very little apron taper, but I am at a loss as to how to improve on it.
Also, how much wider should the aprons be at the bottom (selvage)? (total length 22")
Any help and advice appreciated.
