Results 1 to 10 of 14
Thread: There's a Bump!
    11th February 13
    Marietta, GA.
    19 Post(s)
    There's a Bump!
    This is my first pair of hose that I wear the traditional self tying garter. When I tied up and slipped it back under the "wrap around" I have a bump that shows it's there after my hose are folded down over it.
    Am I doing something wrong?
    LOCH SLOY!
    Cheers, Wil
    No. However, after a bit of practice you may be able to tie a tidier and slightly smaller knot. Many of us avoid all that by using elastic garter ties, but its not an issue either way.
  3. The Following User Says 'Aye' to Jock Scot For This Useful Post:
    12th May 11
    Lakewood, Colorado
    You must be--I always get a lump with my garters, not a bump. You really screwed up somewhere!
    I think it's normal, as long as you're okay with it.
    Mister McGoo
  5. #4
    11th February 13
    Marietta, GA.
    19 Post(s)
    Yes I do have the elastic ones and have always worn them without the bump. But I did get some new "smart" looking hose that has the self tie. Ok I will sausage through.
    LOCH SLOY!
    Cheers, Wil
  6. #5
    I have found that you don't have to actually tie a knot, to keep them secure. Once the garter is round your leg fold one end over and under, go past it with the other and do the same. Friction and the fact that both ends will 'lock' together holds your hose up.
  7. The Following 2 Users say 'Aye' to Chas For This Useful Post:
  8. #6
    11th February 13
    Marietta, GA.
    19 Post(s)
    So Chas,
    I wrap the garter around my calf, then as the ends (that I am holding) cross paths I just let them rest in an "X" and they will hold?
    LOCH SLOY!
    Cheers, Wil
  9. #7
    14th October 10
    Los Alamos, NM, USA
    Quote Originally Posted by Wil View Post
    Don't feel too bad about the lumpy bumps unless they really bother you. It happens, ... though as written above you will get better minimizing the effect with practice.
    Below is one of my best "bump" pictures taken AFTER (my son and I look a bit weatherworn due to all the haggis and gravy) this year's Burns dinner. Note that it's so bad the top of the hose is pulled down a bit. Some of that is due to my barely visible sgian dubh.
  10. #8
    11th February 13
    Marietta, GA.
    19 Post(s)
    Quote Originally Posted by mookien View Post
    Hey that's my bump...lol Well I need to get cracking because I need to wear these hose on Sunday and I would rather it not be so noticable....
    LOCH SLOY!
    Cheers, Wil
  11. #9
    14th October 10
    Los Alamos, NM, USA
    The technique described by Chas seems to hold promise. I plan to try it next time. I, too, have noticed that the friction alone between the garter material and the two layers of hose tends to keep things in place. Good luck!
  12. #10
    6th February 10
    U.S.
    Wil,
    Check this instructional video out, courtesy of our own Matthew Newsome:
    http://giftshop.scottishtartans.org/garter_howto.html
  13. The Following User Says 'Aye' to creagdhubh For This Useful Post:
