Results 1 to 3 of 3
    Three different ways to Make Kilt hose Flashes
    Originally Posted by Barb T. 12/2/07
    I've been experimenting lately with a variety of materials for easily making really nice-looking flashes from tartan scraps. I wanted them to look nice both front and back, not be prone to raveling, be fast to make, and be comfortably flexible (not stiff as a piece of cardboard).
    The instructions below use what’s called fusible web, an iron-on material that is heat activated on _both_ sides (unlike fusible interfacing which is heat activated on only one side). I’ve experimented with making flashes with lots of different double-sided fusible materials. Some don’t stick very well to tartan. Some types aren’t readily available in strips that are wide enough (about 1 ½”) to make good flashes (e.g., Stitch Witchery is great, but the widest that's available is 1 1/4"). And lots of fusible materials are too heavy and make flashes that I don't like because they are too stiff.
    The best fusible material that I’ve found is called Lite Steam-A-Seam 2. It’s available at Joann Fabrics stores and at www.JoAnn.com. Lite Steam-A-Seam 2 irons well to tartan and also has the convenience of sticking temporarily before ironing. Flashes made with Lite Steam-A-Seam 2 are stiff enough to be attractive but retain a nice flexibility. And the fusible aspect keeps the tartan from raveling.
    The instructions below produce four flashes, two for each garter. I like to match the tartan in all four, or make them in two sets of mirror image pairs. But, if you have a tartan with a big sett, this actually uses up quite a bit of tartan. If you have only a few scraps of tartan (such as those left over from cutting out the pleats), you can certainly make non-matching flashes.
    For the flashes, you'll need:
    -four 3”x7” rectangles of tartan (7" is an approximate length and will make a finished flash that's about 5 3/4" long) - shorter or longer is OK)
    -four 1 7/16”x7” pieces of fusible web (see note above)
    -four 5” lengths of black iron-on hem tape
    If you need to make garters too, you'll need:
    -two 18” lengths of ¾” no-roll elastic (this will fit just about anybody)
    -two 4” lengths of ½” Velcro (gives lots of adjustment)
    Peel one side of the backing paper off a strip of the fusible web. Center it on one of the tartan rectangles; don’t peel off the other paper. Iron the paper side of the web.
    Leaving the paper on, fold the two sides of the tartan rectangle so that they meet in the center of the back of the flash. Press to set the crease. Leaving the paper in gives you a nice sharp line to fold along for pressing the edges. Open up the back of the flash, and peel off the other paper backing. Fold the sides down again, and press the flash well to fuse the web.
    Flip the flash over, and press again from the front side. Lay the piece of iron-on hem tape over the join on the back side of the flash, having the end even with the lower edge of the flash (the tape doesn’t need to go to the top of the flash because you’ll fold it over). Iron the hem tape.
    Zig-zag the top raw edge of the flash, if you want. Then fold the top edge over about 1 ¼”, and stitch close to the zig-zagged edge. If you don't have a sewing machine, you can cut another little strip of fusible web, slip it under the edge of the flash, and stick it together with the iron. Just be sure to leave enough of a channel for the garter. Cut a notch out of the bottom edge of the flash.
    If you need to make garters, too, stitch the hook and loop parts of the Velcro to opposite ends of the lengths of elastic. Make sure that you put the hooks on one side and the loops on the other.
    String two flashes on each garter, and you’re done!
    Barb
    Originally Posted by Barb T 12/02/07
    Original thread can be found here:
    http://www.xmarksthescot.com/forum/m...x.html?t=32660
    Flashes on the Bias
    Originally Posted by The Wizard of BC 12/12/07
    I remember that there was quite a discussion on making flashes at Kilt Kamp.
    I, of course, do things slightly different from Barb but basically the same. So I thought I'd show you how I do them.
    We all do things a little different and so should you. Experiment, have fun.
    Here are some shots of some matching flashes for a Kilt in the Nova Scotia Tartan.
    I use a fusable non-roll waistband interfacing. It is exactly 1 1/4" wide so it gives a good clean fold. Laying it directly on the fabric allows me to layout on the diagonal easily. Lay it out, then iron it down.
    The interfacing I use is stiffer than the what Barb uses and I think I'm going to try some of hers.
    here's a shot folding over the fabric on the back side. I then use stitch witchery fusable to hold it down.
    Another shot of the folds on the back side.
    One of the different things I use is black fusable wiastband interfacing for the back side. This is known as "Jiffy Waistband" and is perforated in the middle to make it fold easy. I just cut or rip it down the middle and use one half. I think if gives a good looking clean appearance to the back.
    I then use the corner of a drafting triangle to cut the notches. I do the cut with an Olfa circular cutter and finish them with scissors. Then a touch of Fray check to seal it up.
    Then sew down the tops for the elastic.
    A little trick I do is to sew a small bartack at the top and bottom of the elastic loop. It helps keep the flashes straight and together.
    The finished product.
    Original thread cab found here:
    http://www.xmarksthescot.com/forum/a...x.html?t=32921
    Originally Posted by O'Neille 8/22/06
    I decided to make single flashes that wouldn't be huge on a ladies calf. I made two of each of the base colors of the kilt (blue and green). So that they would be reversible and the wearer would have more choices in hose to wear with them and the kilt. You could always double the recipe for men's flashes.
    First I made 1.5 inch strips of light weight black canvas about 16" long that I attached to the 11" strips of tartan using hot fusing. You can buy the fuseable canvas but I made do.
    I then used more fusing to attach the two different colored halves together.
    Then you cut them and notch them.
    I serged the edges of the canvas befor folding over and sewing it down. to form a loop for the elastic.
    Then insert lengths of Elastic (wait for email re: calf size) and finally sew on velcro.
    There you have it reversible flashes. O'Neille
    Original thread can be forund here:
    http://www.xmarksthescot.com/forum/m...x.html?t=20317
  1. 29 Flashes Does Not A Kilt Addict Make
    Last Post: 21st January 07, 05:05 PM
  2. How do I Make Flashes from Kilt Material?
    By sorcererdale in forum Kilt Advice
    Last Post: 2nd January 07, 06:34 PM
  3. I need to make flashes
    By krooks in forum How to Accessorize your Kilt
    Last Post: 9th May 06, 01:24 PM
  4. Ways to Make a Saffron Colored UK...
    By Riverkilt in forum Contemporary Kilt Wear
    Last Post: 15th August 05, 07:56 PM
  5. Anyone know how to make their own hose garters and flashes?
    By The Kilted Chef in forum Kilt Advice
    Last Post: 18th May 04, 01:52 PM
