Results 1 to 10 of 23
    1st August 11
    Villa Rica Georgia
    What kind of glue to use ? for Horse hair sporran
    Just wanted to get your thoughts on Glue .
    I am making a horse hair sporran and I need to glue down the hair then sew it.
    I was wondering what kind of glue should I use ?
    Thank you
    25th September 11
    Missouri
    Barge All Purpose Cement in the red and yellow can works well with leather.
    20th January 12
    The Northern Appalachian Highlands of Southern Ohio
    I like WeldWood contact cement for most leather applications.
    14th July 12
    St. Paul, Minnesota
    Barge Tanner's Bond Contact Cement (sold by Tandy). Although, to tell the truth, I don't see much difference between it and WeldWood. However, since it's made specifically for leather, it's my "go to" glue.
    1st August 11
    Villa Rica Georgia
    awesome thank you all for the ideas , how does these hold up on Horse Hair ?
    The problem I am having is , I dont want the hair to slip out of the glue.
    I will glue one line in the middle and sew two lines , one on each side of the glue .
    Do you think this would hold ? with the Weldwood ?
    TX
    20th January 12
    I would suggest that you string very small bundles of horsehair, each tied and glued separately, to sew your rows onto the leather. That way, you can more easily ensure that the end of each hair is coated with cement and will hold.
    1st August 11
    Villa Rica Georgia
    Quote Originally Posted by David Thorpe View Post
    That is a good idea ! thank you
    7th February 11
    London, Canada
    And don't forget that horsehair is actually porous which means that the glue will soak into it, as well as into any un-finished portion of the leather. Binding and gluing the tufts first sounds prudent to me.
    11th July 11
    Vancouver, Washington
    "Barge Tanner's Bond Contact Cement (sold by Tandy). Although, to tell the truth, I don't see much difference between it and WeldWood. However, since it's made specifically for leather, it's my "go to" glue."
    I agree with MNlad on this. You can brush it onto both surfaces and let it dry for a short bit then align your pieces and press them together. It will hold the pores of leather well and that's what it's made to do.
    May you live as long as you want and never want as long as you live
    Kerrville, Texas
    8 Post(s)
    Barge cement is wonderful stuff. Do follow Oberu's advice on letting it get tacky on both pieces (in this case, leather and hair) before pressing them together. When followed up with a firm stitch line over the hair, it should hold just fine. Unless you have children yanking on your sporran or something...
    By the way, speaking of Barge, last time I was at Tandy, I noticed they only sell it in small squeeze tubes for regular customers. I needed a big can of it, and was told that they cannot sell it to the public without a tax ID number. Fortunately, we have a tax ID so it was no problem. But does anyone know why they would do this? Are kids using Barge for huffing or something?
