Results 1 to 3 of 3
Thread: X-Kilt Question
    21st August 10
    X-Kilt Question
    How do you determine the width of the under apron?
    I made two that I just kind of guessed, and they came out fine. However, now that I'm making a third I kind of wanted to know what is intended.
    What I was guessing from the sample diagram in the Appendix was simply adding six inches to the width of the over apron. But is that correct?
    19th May 08
    Oceanside CA
    The under apron comes across about to the left front of your left thigh (mid-way between front and side of thigh). The relationship to width of over apron will vary based on how wide you have chosen to make your over apron, so that 6 inch figure is not hard and fast. The under apron needs to be wide enough to provide coverage when you sit down, but not so wide that it gets in the way while walking.
    You could make it wider, try it on before attaching Velcro (use safety pins), walk around/sit and see what you think. Easy enough to make it narrower at that point -- nobody will see if your waistband is less finished on that end!
    Sorry it's not a precise answer but that is part of the "craft" nature of kilting! And others may well offer differing advice.
    There is no right answer. Make it wide enough so that an errant breeze won't reveal the family jewels, or the paisley pattern of your grundies, to your neighbors. Beyond that...whatever you want. My personal rule of thumb is to make it wide enough that it fastens well over on my left hip.
    Well, I'd suggest not making the underapron so wide that it wraps around you, twice, eh?
